Question about HEWLETT-PACKARD Hewlett Packard HP EliteBook Mobile Workstation 8540w Core i5 520M 4 GHz 156in TFT PC Notebook
Keyboard space button does not work, nor in Bios
    Brigadier General:
  • 8,909 Answers
If the keyboard is not working properly, first try a USB keyboard as it may be a driver issue.
If the USB keyboard works, you probably need a replacement keyboard.
Have a browse in ebay for keyboards.
Posted on Mar 23, 2011
How do I unlock the keyboard on an acer?
try booting it is safe mode and see if it works and then if it does then reboot it again in reg mode. you can also try using a external usb keyboard to have it redetect it again. just a thought.
Aug 08, 2014 | Acer Aspire One PC Notebook
Right and left click do not work, space bar slow
Hi
As you said that the Right and left buttons are not working as well as the space bar, then it could be the issues with some dust particle inside the keyboard.
Try to clean it. Try to use it hope it will work , but in case it don't work then you need to replace the Keyboard.
In case if you have any more trouble do contact back in Fixya.
Thank you
Aug 11, 2012 | Sylvania Computers & Internet
Why cant i use my space bar?
have you rebooted? boot into bios and see if you can backspace or normal space there, if nothing works i'd just replace the keyboard
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 28, 2012 | Acer Computers & Internet
HOW DO YOU GO TO THE BIOS SET UP?
Put your system on for the first time after a second press (F2 ) keyboard button immediately. Bios setup will display, if it didn't work out then off the system again and restart after a second press (F9 ) keyboard button immediately,Bios setup will display.
Nov 23, 2011 | Sylvania G-Netbook
On my Toshiba Satellite Laptop I have opened and started the computer but can't get past the sign in window because my enter key and space bar won't respond. I can type letters but can not enter...
> hardware problem or software or keyboard?
Experiment #1: turn the computer off. Connect a USB keyboard. Turn the computer on. Use that keyboard to try the 'TAB' key (to move from field-to-field). If TAB works, then try using the SPACE or ENTER keys.
Experiment #2: turn the computer off. Turn the computer on, and look for the message:
PRESS <blah> to ENTER BIOS SETUP
When you see the message, press the <blah> key. On the BIOS SETUP menus, try the ENTER key to "select" a field, to prove that the ENTER key works fine.
Experiment #3: Turn the computer off. Disconnect the AC power. Remove the battery.
Remove the disk-drive. Take the original CD/DVD disk, and start to install Windows to the disk-drive. As you work through the installation screens, you'll need to press ENTER at least once,
if only to acknowledge that installation cannot proceed, because the disk-drive is not connected.
If the ENTER key works, it works.
Experiment #4: Like #3, but connect a different, empty, disk-drive, and reinstall Windows.
If it completes, then your "original" setup has a SOFTWARE problem.
Jul 14, 2011 | Computers & Internet
Left side space bar does not work
The space bar on any PC is a single button you may need to make sure your keyboard is clear of any debris If that doesn't fix issue you will probably need to replace keyboard which is very easy to do. techsupport@grindstaffscomputerservices.com
Mar 18, 2009 | Acer Aspire 5735 Notebook
The backspace button and all the arrow buttons will not move more than one space even when I hold them down.
Tried diff kybd? If same prob, then go into BIOS setup (F2) before XP boots, & check any kybd settings ie -repeat ON
If diff kybd works ok, then you prob have a bad kybd
Nov 30, 2008 | Dell 0Y3740 Keyboard
Toshiba Satellite P105 S6012 - Laptop Keyboard Problem
Have you tried reducing the repeat delay and increasing the repeat rate? This sometimes help if you type too quickly for your keyboard.
If this doesnt solve it, the BIOS sometimes has a setting Typematic rate this can be adjusted to increase keyboard sensitivity too.
Aug 19, 2008 | Computers & Internet
Keyboard?
WOW THATS A GOOD ONE. IS YOUR KB ERROR REPORTING ON IN THE BIOS SETTING? YOU WERE NOT ABLE TO INSTALL OS YET RIGHT?/
KB WORKS IN THE BIOS? BUT DOESN.T WORK IN THE OS SETUP?IS THAT CORRECT? XP?MOTHERBOARD?
YOU TRY F8? RETURN TO LASTYKLNOWN WORKING CIONFIOGS?
ARW YOUR KB PORTS ENABLED IN THE BIOS?I NEVER ENCOUTERED THAT ONE.TRY TO F8 IT.IF NO WORK GIVE ME MORE INFO.
Jan 28, 2008 | Compaq Presario 5000 PC Desktop
Usage of keyboard
right click in keyboard. you can find in the space bar line "
from left;
CTRl, logo windows, Alt,space bar,Alt,Logo windows,right clickkey,Ctrl.
You can identify right click key cause there's an arrow pointer on it.
Jan 14, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
HEWLETT-PACKARD Hewlett Packard HP EliteBook Mobile Workstation 8540w Core i5 520M 4 GHz 156in TFT PC Notebook Logo
537 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
