Question about Fujitsu CP217703-XX LAPTOP LCD SCREEN 12.1" XGA CCFL (SUBSTITUTE PART NO.) (22099255284)
Need to depress screen to get screen to light up must hold down top of screen for it to work
    Scholar:
  • 80 Answers
Hello there,
You need to have your monitor serviced. There must be connections that are loose and this might cause further problems with your computer. it might also damage your screen if you keep on pressing it,
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Posted on Mar 23, 2011
Ice maker works fine and ice comes down but when it goes to crush the ice it wont crush it jams up
Remove the ice bin, examine the metal arm on the back of the bin. This arm needs to move up and down freely, this arm is the shifter for the cube and crush setting. Also look at the square hole in the back of the freezer where the bucket came out of, the shifter in there needs to be down all the way also.
With the freezer door open, depress the cube setting on the door, hold the light switch and depress the dispenser button, do you hear a click? If so the shifter works in the freezer and the problem in in the bin itself. With no model number given, I have to assume the ice bin is not in the door, its inside the top portion of the freezer section.
Good Luck
Nov 05, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hı sharp xg xv2e lamp tımer reset?thanks
hi
Do the following for resetting the lamp hour
1.Attach the power cord to the projector and plug it into an electrical outlet.
2.Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button. 3.Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
ok
Feb 04, 2011 | Sharp Office Equipment & Supplies
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Help! There is a red light by the printer light and at the top a key that looks like a wrench (?) is also red? It won't let me copy or scan.
    you will need to reset your machine to clear the error.
    Enter the SP mode by entering, Clear Modes, 1,0,7, then hold down the Clear/Stop Key for more than 3 seconds. Then enter the Copier SP mode.
    To reset the DSM 651, enter the SC code reset(if you don't know the reset code check your manual, documentation or the side panels of your printer) and select '1'.
    Next, depress the 'Photo mode' key. While depressing the 'Photo
    mode' key, depress the # key at the same time and hold both keys for at least 3 seconds (it is not necessary to turn the main switch off and on). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to try the reset procedure again.
    Jul 31, 2010 | Gestetner DSm651sp All-In-One Laser...
    What is the EE message on the DuoTherm Comfort Control Center?
    It means that an error has occurred. If you have a 4 button comfort control. Follow these steps to reset:
    To initiate a RESET, do the following in the order
    listed:
    1) Turn control on to ensure annunciator data and light are present. If data and light are present, continue to next step. Depress MODE switch to activate annunciator light.
    Simultaneously depress the bottom two buttons (temperature UP and DOWN) and hold.
    While holding these buttons down, depress the MODE button once and release.
    Release the two buttons previously held down. Depress the MODE button once again.
    At this time the light should extinguish, and the mode should register “OFF”. If not, repeat these steps.
    Retest system ensuring that all functions are present
    and operational.
    If you have the five button comfort control. Turn the unit off and hold down the mode and zone buttons together. While holding them down, turn the thermostat back on. Hold the buttons down until an FF appears on the screen. Release the buttons and the display should return to normal. If not, try it again.
    Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
    My compressor will not start.
    There are a few more things to try, in the control unit of the AC there is Cold Control/Freeze Switch. Take down the control unit (inside unit, remove inner shroud) and remove the cover, The freeze control is plugged into the blue plug on the board. Remove the plug and install a jumper wire in its place. Does the compressor come on? If so, you have a bad freeze control. If not, then we need to check and see if your AC power module is sending power to the Compressor. Check power across the relay in the control unit, Black to Blue. If the blue wire is hot, then you need to go upstairs to the top of the compressor and check the thermal overload. If the blue wire is not hot, the comfort control center may not be sending a signal to turn the compressor on. If it is not, do a reset of the CCC. For a five button system, turn the tstat off and hold down the Mode and Zone buttons simultaneously. While holding them down, turn the CCC on and hold the buttons until FF appears on the screen. Release the buttons and try the AC.
    Four button reset -
    should register “OFF”. If not, repeat Steps 2 through
    6.
    and operational.
    Hope this helps,
    Jeff
    Rate me please!!
    Jun 28, 2009 | Dometic 57915531 Air Conditioner
    When I push start it beeps 3 times. Lights on the right work, lights on the far left don't light up.
    Alright, pretty unconventional, but simple and Genius on my part!!! Not sure if we're talking about the same models, but I was cruising this site with the same problem.... K, so it's making three beeps right? Check inside the DRYER (maybe same issue w/ washer, I dunno), but there's a button on the top-inside.... DEPRESS THAT BUTTON, and while holding it down, START THE DRYER (HOLD TO START), if it starts working, this tip is for you!
    1) on the opposite side, where the door depresses that same button on the dryer door... you ready for this... see step two ;)
    2) SUPER GLUE A PENNY IN THAT INDENTATION PART, your problem is there's not enough connection, and the door is no longer holding that same button down...
    3) TA DAH!! Since a repair guy could've charged ya like 50+ bucks, I'll take... emmm.. 25$, email me at Kumatrev@yahoo.com on where to send the check, or just shoot me an email to say thanks ;)
    May 29, 2009 | Kenmore Elite HE4 Electric Dryer
    POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
    bjw122266 Have you tried holding the power button down for about 10 seconds or so?
    Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
    Ice maker quit working
    good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
    theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
    Oct 31, 2008 | KitchenAid KSCS25IN Side by Side...
    Fujitsu CP217703-XX LAPTOP LCD SCREEN 12.1" XGA CCFL (SUBSTITUTE PART NO.) (22099255284) Logo
    49 people viewed this question
    Top Fujitsu Computers & Internet Experts
    Alun Cox
    Computer Links
    Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
