Question about Grip On Tools Non Contact Handheld Infrared Thermometer
What are the instructions for using the ABW Non-contact Infrared thermometer 70618 instrument properly
2006 chevy implala dashboard reading engine hot ac off. Already replace sensor
Is engine overheating ? Buy a Non-Contact Infrared Digital Thermometer LCD Digital Pyrometer Temperature GM320 11 99 Non Contact Infrared Digital Thermometer LCD Digital Pyrometer... Check temp at upper radiator hose , at 221 degrees the cooling fans should come on ! If the fans come on the sensor isn't the problem isn't the problem . The gauge it self could be bad , or the stepper motor that controls the gauge .c How to repair GM Instrument Cluster Speedometer Gauge Stepper
Feb 04, 2017 | AC Cars & Trucks
After heating up the engine, when you shut it off i wont start anymore, what is the defect?
Sometimes plugged cats can severely overheat expanding the catalyst material and blocking normal aspiration. if it starts ok when cool, check cat temps when running with infrared non contact thermometer. bad cats will often display temps in excess of 500 degrees. cats are built into manifolds on the six cylinders, one front one rear. sometimes heat shields prevent a good measurement.
Mar 29, 2016 | 2004 Hyundai Santa Fe
Beechams forehead thermometer instructions
Why not check out a non-contact digital thermometer? I think that would be easy for you to measure someone's temperature.
Catherine J. Davis
Non Contact Digital Thermometer
Aug 28, 2014 | Home
My 2001 chevrolet venture minivan is over heating. Its got a fairly new water pump replaced in jan of this year, and i replaced a busted heater core hose. Then filled radiator back up with water and...
Is the vehicle really over heating would be the first thing to address . If this vehicle was brought to the chevy dealership I work at , hooking up the factory scan tool to see what the PCM - engine computer is seeing for coolant temp . Too see if the cooling fans work , too see what temp info . the PCM is sending to the instrument cluster . I know GM had stepper motor problems in the instrument cluster . The step motor is what makes the temp , fuel , speedo , tach , gauges needles move . Just replaced a cluster in a 2005 chevy cavalier , temp. gauge goes full hot after just starting the vehicle . The cooling fans should kick on at around 223 degress , do the cooling fans come on ? Given the amount of electronics on these vehicles , it maybe best to take it to a qualified repair shop . That knows how to test these systems . Without testing I would only be guessing as to what could be wrong , Unless your prepaired to replace a bunch of parts , because your going to get a lot of different cause's from on here . Testing is the proper way to finding the problem . If you don't have a scan tool to view engine sensor data parameters , temp sensor. At harbor freight they sell a Non-Contact Infrared Thermometer With Laser Targeting. This will show what the temp is .
Non Contact Infrared Thermometer With Laser Targeting
Overheating Case Study Ford Explorer 4 0 SOHC Part1
May 01, 2017 | 2001 Chevrolet Venture
Rinnai temperature flucuates water
Hook up a professional scanner an see what the actual temp of the engine is . Coolant temp. sensor is a input to the PCM - engine computer . Go to harbor freight tools an buy a Non-Contact Infrared Thermometer With Laser Targeting What's the temp at the thermostat housing . Does the temp.'s match an the gauge is off . Testing an not guess as to what the problem is.
The PCM sends temp. info to the instrument cluster via the class2 serial data bus . I have seen a number of GM instrument cluster issue's over the year's . Could be a electrical problem , an the engine temp is correct .
Nov 29, 2017 | Cars & Trucks
Calibration for craftsman 1000 degree infrared thermometer
Apparently the reason it is not accurate is that it is a Piece of crap and Sears will not stand behind it. I recommend you do not purchase any type tool that requires precision from Sears.
Jan 05, 2013 | Craftsman 1000 Degree Infrared Thermometer...
Need instruction manual for equity wireless thermometer
Hi George,
I believe your Equity wireless thermometer is manufactured by LaCrosse Technology. Here is a link to their website:
http://www.lacrossetechnology.com/
From this page, you can search the type of wireless thermometer or weather station you're trying to use. (You didn't specify a model number in your request).
Also notice that there is link on that page for Support; clicking that will take you to the Manuals link. You will need to find your proper model number in the drop-down menu.
Also, there is a Contact link, so you can contact them directly for further assistance if you are unable to find your model's information.
Good luck, George! Hope this helps!
Feb 11, 2012 | La Crosse Wireless Thermometer
Hi: Recently I changed the radiator and the main hose of my Escape 2001. The car was sent to a Ford dealer to fix other problems and they checked the car and is working ok, however, the engine temperature,...
Normal engine operating tempurature can vary from 180 to 220 degrees depending on the age of your car and what kind of modifications it's had done to it.
Your 01 Escape is going to be normal in the 200 to 220 range.
Jan 08, 2011 | 2001 Ford Escape
1998 Pontiac Sunfire Symptoms: -Overheating
What are you going by to say it's overheating , temp gauge ? Have you test to see what the actual temp. is > Hook - up a scan tool ,what's the PCM - engine computer seeing for engine temp. ? 223 degress the PCM should turn on the cooling fan . You could buy a Non-Contact Infrared Thermometer With Laser Targeting at harbor freight ! Radiator very hot ????? What is the right temp .
Could be a bad temp gauge . Is the coolant surging inside the cooling system ? Does it have a radiator cap ? Have you replaced it ?
May 06, 2017 | 1998 Pontiac Sunfire
Grip On Tools Non Contact Handheld Infrared Thermometer Logo
95 people viewed this question
Top Grip On Tools Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Grip On Tools Measuring Tool and Sensor Expert? Answer questions, earn points and help others
