I have horizontal picture and lines, something blew behing the tv
    President:
  • 1,654 Answers
What blew was a capacitor on one of the boards. You can look them over for a blown cap, it will be mushroomed or split or bulging. Make sure the set has been off at least a half hour and cross the prongs on the plug with a screwdriver to spend any stored electrictiy in the unit before attempting to open the set. Most likely the bad board would need replaced. If this set is older model, maybe better to replace the set with a new one. These repairs tend to get messy, once a board goes bad, other boards start going bad and so forth till the money you spend would have bought a new set.
Posted on Mar 23, 2011
Rolling horizontal (colored) lines instead of picture; audio OK
This problems it pretty easy to fix.Just require take the tv apart.Resolders all the holes in the video board that connected to a long CRT tube neck.Should cost $50 -$75 more than that u are being cheated.
Dec 04, 2009 | Philips Magnavox 20MT4405 20" TV
No picture on my tv and it has a horizontal line mid screen
either your vertical driver or output circuit capacitor(s) defective, try this remove rear cover and with something insulated like a straw prod and poke around the circuit board,sometimes theres a cold solder joint, if picture starts to expand on screen its a solder joint
Oct 18, 2009 | Televison & Video
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
Lines on tv
Hi
this not horizontal this is vertical line. this means defective vertical output IC and 1.5ohms resistor, Replace the two parts then test run, and happy viewing!
Thanks!
Dec 26, 2008 | Sharp 25L-M100 25" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
TV - Thin horizontal line picture on screen
Is this a LCD TV? IF it is it could be something on the video processing board. Let me know the model # and well will go from there. Thank you Jay
Jan 31, 2008 | Televison & Video
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
568 people viewed this question
Top Televison & Video Experts
