Question about Microwave Ovens
Microwave dish/tray rotates intermittently.
i have a samsung model no CE118KF microwave.it's about six years old. of late the glass dish/tray stops rotating intermittently when the m/w is switched on.the fault is diagnosed as the motor going bad. should i go ahead and change the motor? also, the m/w heats up things very quickly now as compared to earlier.the glass tray/or any vessel get very hot even with just a minute of heating which was not the case before. any corelation with my motor problem? please advise. grateful for your time on this.
  • pils Aug 04, 2008
    hello,
    the excessive heating occurs even when the turntable rotates sometimes(it rotates for the entire cycle of time punched perfectly and sometimes it stops in between the cycle) any particular reason ? ty for the confirmation.will change the motor and check the plastic coupler too.
  • Microwave Ovens Master
  • 9,098 Answers
If the turntable is not turning, you will get hot spots and uneven heating.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can get Samsung parts here.
Posted on Aug 03, 2008
What size glass tray do I need for my Westinghouse model WCM770B/W microwave? I broke mine and cannot find the answer in the manual.
Frequent thrift stores or yard sales, or take a tape measure to the inside of the microwave
. If your dish was square, the glass plate should likely be about 1 inch less wide and 1 inch less deep that the inside of the box.
If you have a round plastic rotator, the dish should be about 1 -2 inches bigger in diameter than the plastic rotator.
God bless your efforts.
Oct 23, 2017 | Westinghouse Microwave Ovens
My ge micro will not stop turning
HELLO.
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Thanks.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I bought a house with this Microwave - no instructions etc.Should there be a glass tray for it - I know it's an older model
If there is a recess for a tray and a drive in the middle of the floor of the oven, then it should have a rotating tray. My microwave is about 30 years old and has a rotating tray.
Feb 25, 2011 | Microwave Ovens
My 2 year old Kenmore Microwave Model 721.66229 just stopped working. The light comes on when you push start, but the tray will not rotate and no heating happens. Help??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[p][p]
Jul 07, 2010 | Kenmore 63663 Microwave Oven
Our Kenmore model 721.80833500 tray jumps off its track. This has progressively gotten worse over time and now the little end wheel on the rotating arm has broken off. The microwave still works and still...
Found 2 possible solutions on the net. (1) Check the engineering change at a Sears store. They reengineered the glass tray and the narrow plastic band the tray glides on. Get the new items from Sears. (2) Cut 1/4" out of the narrow plastic band the glass tray glides on. Possible solutions that look promising.
Dec 03, 2009 | Kenmore 80809 Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Feb 28, 2009 | GE JVM1651 Microwave Oven
Kenmore elite microwave/vent hood model 721.80834500 turntable
I bought a Kenmore Elite Microwave Hood Combination Model 721.80823500 at Sears. The installer did not bring the parts to connect the vent to the pipe on the ceiling and never came back. I cannot find the vent/exhaust connetor part to have it installed. No one knows. I appreciate information or installer. Thanks.
isabelmvaldes@gmail.com
Nov 16, 2008 | Kenmore 63792 Microwave Oven
SAMSUNG Microwave Oven Model MD800WC/SC The Glass Tray does not rotate The oven heats OK.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can see and hear a YouTube video of how a turntable motor should sound when you rotate it by hand.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it. You can get parts here.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 30, 2008 | Samsung Microwave Ovens
Microwave Ovens Logo
276 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
