Question about Brother IntelliFax-4100e Fax
Line on fax when sending or coping.
When I fax there is alway a line going throug the page. I can print to the fax there is no line, The line is also there if copies are made. I purchase a nes drum but that did not correct the problem,
    Genius:
  • 2,120 Answers
Open the document feeder (the keypad assy) and look for wite-out on the small scanner glass.
Posted on Sep 26, 2008
I Cannot Receive a Fax - the pages are blank
A second line isn't needed, this wouldn't cause blank pages to be printed. This could cause fax's not to be received if the line is in use. There could be 2 causes of blank fax's. Either the obvious which is the person sending the fax is faxing the document the wrong way up. Or the fax board on your copier has a malfunction. Because of the copier's age, this seems likely, although i hope not. hope this helps.
May 07, 2013 | Sharp AR-M355N Copier
There is a line going down my paper when I print a paper
If the line is on pages you print out, but not on faxes that you send, the most likely solution is to replace the drum and toner unit. If the line is also on pages that you send, try cleaning the scanner glass -- there might be dirt, Wite-Out, or other debris on it.
Aug 11, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
WHY DO I GET A BLANK PAGE AFTER EACH FAX?
The fax machine that is sending you the fax may be also sending a confirmation page that is not needed or compatible with your machine.
I have an older machine that prints a confirmation page after each fax. People on the other end sometimes receive a blank page after each fax that I send them while my machine prints a mostly blank page with only a single line of text at the top with the date and time.
Feb 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Cant receive faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Sending a fax
Its the phone line causing the problem. Check the line via the handset, if you hear static sounds you have a bad line. Contact your phone provider and have it checked/fixed.
Also check the feeding of your original by using the copy function. It is possible that you have a feeding issue but I would bet on it being the line.
Feb 20, 2008 | Brother FAX-575 Plain Paper Thermal
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Brother IntelliFax-4100e Fax Logo
88 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
