Question about Refrigerators
I require a thermostat for a Centrex fridge model CTBF130/CTBF130B
Fridge not cooling
What your describing sounds very much like a faulty compressor or a leak in the system
Jan 02, 2018 | Refrigerators
I have a F&P Fridge Model c270 that the thermostat is not working and within 24 hours drops the temp to -8c.
more information required. What is the product ID on the grey label on the bottom right of the cabinet when you open the door?
Have you transported the fridge recently?
Dec 03, 2016 | Refrigerators
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Fridge & Freezer cool down to -4 & 38 respectively then heat up to 50 to 60 both sides then cool down again.
It sounds like you may have an issue with the defrost timer / defrost thermostat (aka defrost terminator). These aren't expensive or difficult to replace. It will require unloading the food from the freezer compartment and accessing the cooling coils to remove the thermostat. The timer is located under the fridge - behind the toe kick area on **MOST** fridges. You didn't provide the make / model of your fridge - so I can't tell you the specific locations of these parts.
Jul 20, 2015 | Refrigerators
I have centrex Air Cond. Model CTAR60GW.Does it meet the EER Rating above 2.9?
Centrex should be able to confirm the EER if you inquire.
Dec 04, 2014 | Heating & Cooling
I require a wiring diagram for the thermostat of a Hoover nextra HMA 280B fridge freezer on
Not sure about this model but most thermostats have only 3 terminals... 2 live terminals and 1 earth.. The earth is usually the terminal on the main outside frame or body of the thermostat. There is usually a wire from active or the + side of the main terminal block or supply cord. The other terminal usually goes to the compressor. Basically, a thermostat turns the compressor on and off to maintain the temperature in the fridge its just an on / off switch..
Aug 04, 2011 | Hoover Refrigerators
I'm looking for a defrost timer will go in a 2004 Centrex fridge, model number CTF470P.
YOU WILL HAVE TO ASK THE COMPANY OR THE LOCAL SPAREPARTS SUPPLIER NEAR YOU
Nov 17, 2010 | Refrigerators
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Looking for a lid for a centrex washing machine model ctw60518
We have a Centrex Washing Machine, Model No. CTW 60518 Top Loader, which has recently broken-down. It leaks and not emptying completely on the spin cycle. We are unable to have repaired due to parts unavailable. If anyone would like this machine for parts kindly phone (07) 4936 4185 (Queensland -The machine has not been flood affected).
Vicki
Jul 07, 2009 | Washing Machines
Centrex plasma tv model ctpl42s5
Centrex plasma tv model ctpl42s5 same problem wont turn on have extended warranty, what can we do.
Mar 11, 2008 | Televison & Video
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
