Question about Sony Dual Shock 3 Controller for PlayStation 3
Once the controller goes dead how low to recharge
  • 158 Answers
You will get a notification if you need to recharge it already, just plug the usb cable provided and it will charge, a usual full charge can last up to 3 days
Posted on Mar 23, 2011
Headset won't recharge battery must be dead
That may very well be the case. There is a finite number of charge / discharge cycles a battery can handle. This number varies based on the level of discharge prior to charging, temperature, etc. Some devices can operate via charger alone - and others require a small amount of battery power and a charger to operate. A classic tell tale sign is an older device that has been used regularly and charged every day or night - but was allowed to fully discharge once - due to failure to connect to the charger. Attempting to charge may indicate it is accepting a charge but goes completely dead / dark when the charger is removed. That usually indicates a battery that was drained so low that it will need to be replaced. Good luck!
Oct 19, 2015 | Radio Communications
2010 G37 - battery was dead - jumped it off and drove it for twenty minutes. Next morning it wouldn't start and now it wont stop clicking (like a relay). Any suggestions?
if the battery goes dead or low it must be recharged with a charger, driving the car will not recharge it properly. The alternator is only meant to maintain the battery, not recharge it. Get the battery recharged and verified and then try again.
Mar 02, 2015 | 2010 Infiniti G37 Coupe
2007 Jeep Liberty will battery dead and recharging alot cause transmission to act up
most modern cars and 07 is that.
have electronic shifter brain boxes. called TCMs,
(trans, control module)
the newer cars, have a TCM that learns your cars weight , Horse power and your driving habits. (allowing 1 trans to fit many cars, a very genius idea if ever, lowing the cost of transmissions)
so if the battery goes dead, the TCM brain forgets all that.
and must learn, again, all that.
so drive it. and let it do its job.
this is a generic answer, as you never stated the trans model in car.
some jeeps have 3 or more transmission drive line options.
1 M/T and 2 A/Ts and AWD too.
Sep 17, 2014 | 2007 Jeep Liberty
My proscan tablet won't power up
The tablet may be dead and need recharged. OR so low that it turns itself off. My 10.1" tablet has a reset button on the back that I have had to use once before.
Feb 08, 2014 | Android 7 inch Tablet
Alarm goes off when recharging the battery.
try turning on ignition switch before hooking up charger, once charger is working turn switch off.
May 10, 2010 | 1992 Pontiac Bonneville
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Blades stopped on my 02 cool fan.
I love the 02 Cool rechargeable/battery operated fans and have them running in my home and office daily. However, they do have a limited lifespan. I get about 6-9 months of daily use before the fan motor goes dead and the blades stop turning. However, I'll keep buying them. I live in an area where we frequently lose power and the rechargeable/battery operated feature pays off when it does so on a hot day.
Jun 25, 2009 | Panasonic Dryers
Wont power up
Same unit, same problem. I found that when the internal batt is dead current draw on the USB port is not enough to recharge. I have a USB car adaptor (it is for my kids PSP ) and use it to recharge the batt when it goes completly dead. I keep a eye on the remaining batt life and charge it via the computer USB before it gets to low
Oct 22, 2007 | Audio Players & Recorders
M515 green light on and dead screen
Hey, i had the same problem. My m515 stayed with the green light on for 3 days until the battery died out (and lost all my data). I keep the m515 off and without recharge for 2 more days. Then I recharge it in its craddle and it seems to be ok. Good luck
Sep 19, 2005 | Palm m515 Handheld
Sony Dual Shock 3 Controller for PlayStation 3 Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
