Question about Sharp AM-400 Digital Multifunction Printer
I can not print on a network printer from a windows vista system using sharp am 300/400
    President:
  • 739 Answers
Hi
There are many reasons why the printer failed to print in a network. you should check your network is fully functional, then check the master of a network printer. failure of a master computer overall operations of the network will interfere with printer sharing.
regards
Posted on Mar 23, 2011
Connecting sharp AR 5316 to a wireless network for office use
With great difficulty.... Seriously though, you MUST get the driver for each operating system, Install each Driver on each machine, and then simply connect each computer to the printer as a "Networked" printer. I may be efficacious, to have all drivers on every PC, all in same Directory so that each is available to each other...Right ALL machines, must be in same WORKGROUP, ALL have a password, The printer MUST have a name, Install the drivers as Administrator.
May 12, 2010 | D-Link Air Plus DP-G310 (dpg-310) Print...
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
SHARP AR 5320 sharing problem
for windows vista it wont get installed try on xp
Aug 18, 2009 | Sharp Office Equipment & Supplies
Need to print from Vista 64 bit laptop - no drivers.
try this link http://esupport.sharp.at/html/driver/index.php?StartRec=0&ListLimit=10&TemplateLang=nl&Lang=%&ProdLine=34&SortOrder=DESC&OrderBy=Title&OS=%&EMU=%&SearchString=arm207
Apr 14, 2009 | Sharp AR-M207E Black and White Copier
Scan to computer
Your machine has Vista supported print drivers?
This is where you can go for the Print Drivers.
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Scanning: first your Machine needs network scanning enabled: (if you can scan with other PC's, dont worry about this) this a key you will get from your dealer..
as for scanning there are a few options:
Scan to email which you can scan through the network to your email using your email server..
Scan to desktop
you can use Sharpdesk a program that will come with the machine if Scanning is enabled? which now is available for vista, your local sharp dealer will have(not sold in stores)
or you can try the Twain Scan (LAN).. which you can find on the sharp web site listed above..
Nov 13, 2008 | Sharp MX-2300N Color Copier
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
Windows Vista Printer Driver
Go to: http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
and select the copier and OS that you use. Download the PCL5e driver. When you finish downloading, you might have to extract it from the zip format, then run the setup.exe file and follow the prompts.
Don't forget to rate your answers please!
Mar 14, 2008 | Sharp AR-M237 Copier
60 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
