Question about Compaq Presario 700 470024-192 Notebook
Compaq presario 700F
Blank screen.
When I turn on my computer, the screen is dark. I've tried the function f8 key, but this has no effect.
  • djhankey Sep 14, 2008
    Turned out my laptop was still under warranty. Called HP, they Fed Ex'd me a box with shipping label, got my computer back in 3 days, start to finish, although they told me it might take up to 2 weeks. They had to put in a new screen. Their customer service was fantastic, and the laptop is working perfectly.
Definatley the display close power switch, located under switch/speaker not sure if the hinge activates it or not. looked into mine and found part# tag interfering w/ power switch board, cleaned it up, working good now. discovered this by gently pulling top left and pushing lower right of display, it would flicker.thaught it was closed probably a result of closing it with right side after every shut trying to close only from middle..i also try never to pick it up from one corner, plastic is very bendy and screw comes loose.two hands always, specialy where rom is.i think your monitor thinks its closed. while black hold it under bright light and you can see enough to navigate.tried svid, used it for safemode driver check, took several hours before i got to hinge. i hope this is your troubles as they cost nothing to warrenty left 22 days ago.i was sweating.hope this helps.
Posted on Feb 27, 2009
I have a compaq presario cq 60 to and when I turn it on it just sounds like it's going to start up and goes to a blank bluish black screen if I did it says the main screen and then it goes to that after I...
The blue screen typically would have a error message on it. I would recommend hitting the F8 key once a second after turning the computer on to get the windows diagnostic menu with choices such as safe mode. If you can select this then try a system restore point to when the computer was working properly. If you are unable to have it start up by hitting the F8 key then you either have a failing hard drive or a corrupt windows.
Dec 25, 2014 | Computers & Internet
What keys do I press to get the CMOS setup screen on a Compaq Presario 5222?
Try F2 or F8 or F9. Shouls tell you just before the splash screen comes up ...
Jan 28, 2012 | Compaq Presario 5222 PC Desktop
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
I have a compaq paserio notebook and when I boot up the computer, either I get a blank screen or I get a very faded image that I can't hardly see so I can't log on. Most of the time I just get a blank...
Have you checked the brightness options for the screen using the HP function keys? Fn +F7 or Fn+F8 should adjust the brightness of the screen for that C306 model laptop. If adjusting the brightness has no response then try the next steps.
What happens if you turn the computer off, plug it into an external monitor or projector, and then turn the computer back on? If the video displays correctly on a computer monitor or projector, but it stays dim on the LCD screen of the laptop, then the laptop LCD Screen Back-light or inverter is probably going out. You'll need to contact HP for a replacement part or take the laptop to a certified repair center.
Nov 05, 2010 | HP Compaq Presario C306US Notebook
Laptop powers on disk light flickers & does not start up. The fan is working.Blank screen, when connected to external screen still no output
upon turning the computer on keep hitting the F8 key and see if a repair screen appears. If not the hard drive is gone or the disply is at fault
Aug 02, 2010 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario CQ50 Comes on but the screen is very dark!
The Presario's have an intensity control for the screen.
Mine is holding the function button (Fn) down an pressing F8 for brighter, F7 for dimmer.
The marking on my F7and F8 show an asterisk indicating "sun" for intensity.
Jan 11, 2010 | HP Compaq Presario CQ50-140US NoteBook
Compaq Presario R 4000 to dark when on battery only.
The R4000, or at least mine will appear to be brighter when on battery also. If you press the function key and then the f8 key it will brighten the screen.
Feb 24, 2009 | HP Compaq Presario R4000 Notebook
Blank (dark) screen
If you can still see a faint image on the screen, then its the inverter coil or the inverter itself which has gone bad or maybe even worked itself loose causing a bad connection.
Either way you will have to take it to PC repair shop to be looked at.
Good luck and thanks for using Fixya!
Jan 26, 2009 | HP Compaq Presario F730US Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
180 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
