Question about Canon Pixma iP2700 InkJet Photo Printer
My canon ip2772 (brand new) has a paper loading problem. When I load a paper on its tray, it will **** the paper halfway with green light on the power button lighted but not blinking. When I press OK on my Print Menu, it will continuously sucked two more paper on the tray upon releasing the first one printing nothing. It create a lot of noise especially on the roller. What is the problem on my printer. Can you please help me.
  • 181 Answers
SOURCE: canon pixma mp110 saying ''please load paper and press ok''
there is problem in the paper feeder gears of the printer.they r pulling the paper and then not able to forward the paper as they worn out or slightly cracked.so they needs replacement with deep servicing/cleaning from proper technician .it will be ok after that.
Posted on Nov 17, 2008
SOURCE: I have a brand new canon mp480 printer. it keeps jamming
HEY THERE GUY'S THE EASIEST SOLUTION I CAN TELL YOU TO DO IS CALL CANON COMPLAIN THE'Y WELL MAKE YOU DO A COUPLE OF THINGS THATS SUPPOSED TO CORRECT THE ISSUE: LIKE ROLLER CLEANING A COUPLE OF TIMES, CLEAN THE ROLLER WITH ALCHOL, TURN EVERYTHING OFF AND SHAKE THE MACHINE A LITTLE AND TURN IT BACK ON TO SEE IF THAT WORKS AND FINALLY IF THAT DOESNT WORK THEY TELL YOU TO UNISTALL THE DRIVER AND REINSTALL IT!! WELL MAYBE FOR SOME OF YOU THESE STEPS MIGHT WORK!! BUT L'M TELLING YOU IVE PERSONALLY NOTICED CANON'S PRINTERS ARE ****!!! I'VE GONE THREW 2 PRINTERS SINCE DECEMBER LAST YEAR AND THEY SENT ME OUT A 3RD ONE FREE OF CHARGE!!! I TOLD THEM I HAD A CANON MP 150 FOR YEARS THAT I PRINTED EVERYTHING ON IT AND I STILL CAN EVEN AFTER MY DROPED IT AND BROKE A COUPLE OF THINGS ON IT!! SO FAR I HAVE USED THE MP470 WHICH IS GARBAGE!! AND THE MP480 IS THE SAME!!!! L MIGHT JUST SELL THE ONE THEY GAVE ME!!! IF ANYONE HAS QUESTION FEEL FREE TO CONTACT ME AT jdaguilera28@yahoo.ca SEE YA!!
Posted on May 24, 2009
canontech
  • 1219 Answers
SOURCE: Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Posted on Mar 02, 2010
pineworks
  • 4041 Answers
SOURCE: printer not loading paper to print / error #3
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Posted on Mar 18, 2010
Error load paper and beep when i print
More info would be helpful. Like exactly what is the control panel message. However, from your description it sounds like the machine is looking for a paper size or type not loaded or wants paper loaded in the manual feed tray. Check your driver and see which paper tray is selected and what type paper as well as checking the printer to see if the tray is set to plain paper or some other type.
Nov 24, 2014 | Canon ImageRunner 2525 Copier Canon
Canon pixma pro 100 - "support code : 1000 no paper. Load the paper in the rear tray correctly and press the RESUME button on the printer". How do I fix this?
Try again! Remove the paper from the rear tray. Turn off the printer. Load the tray again making sure that it pressed frimly in and not over loaded - say about 30 sheets. Turn printer on again and see if it is ok. If still the same problem, get in touch with supplier or maker.
Mar 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
Does not recognise the loaded paper
I also had this problem. Had no idea what the problem was. The printer would not print regardless of when paper was put in the upper tray or the side tray. I then read the instruction manual carefully and realized the bottom green light on my printer was lit for the *BOTTOM* tray... I just pushed that button and the light shifted to the top tray and now it works like a charm! :-)
Feb 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Printer says no paper, but there is. Problem loading?
If not paper jam may has some problem with feed rollers on printer.First make sure that option to feed from cassette is turned on.Check this on maintenance mode.Аs the printer is in warranty better don't touch anything else and call Canon.
Nov 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Aug 22, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Printer ML2010 not responding
On Line/Error LED
lights red
receiving data.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Paper Loading Problem
rollers can use a little cleaning sounds like..
Mar 23, 2008 | Lexmark X3350 All-In-One InkJet Printer
Canon Pixma iP2700 InkJet Photo Printer Logo
190 people viewed this question
old marine
old marine
