Not running through the cycle ,Whirlpool AWM 5100
    President:
  • 1,654 Answers
Wher is it stopping, if it is stopping on the rinse cyle, it could be a bad pressure switch or plugged tube to the pressure switch, if it is stopping in the spin cyle it could be the door switch not functioning or a plugged pump filter or pump or clogged discharge hoe. The pump filter is ususally an issue, it is under the tub, usually right in front with some sort of cap on it.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. are you getting any codes, these tell us a lot.
If this was helpful a vote of approval for the free help would be appreciated.
Posted on Mar 23, 2011
5 Suggested Answers
SOURCE: whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Posted on Aug 17, 2008
  • 41 Answers
SOURCE: whirlpool awm 221 washer
you will need a replacement heating element for the appliance
Posted on Jun 12, 2010
SOURCE: why does my Whirlpool AWM
http://www.eserviceinfo.com/downloadsm/14676/whirlpool_AWM5100.html
Above is your service and repair manual. I would think your main controller board has faulted. Most likely it has been spiked or a power surge has affected it. This Board will need to be replaced. All parts are in the service manual, parts numbers too. Now please use the service and repair manual, and perform the troubleshooting steps to isolate this issue and to be sure of our main board diagnosis.
However if you do not wish to DIY, then please contact your local whirlpool service agent and ask for a service call, then ask them for a "Quote" for the repair, before allowing repair work to commence, this way you can make an informed decision as to what to do.
Posted on Sep 14, 2010
caroldon
  • 17130 Answers
SOURCE: Whirlpool awm 5100 stops in random parts of
Problem seems more linked with the program controller unit. Also it is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Posted on Jul 06, 2011
Whirlpool awm 5100
Check voltage to motor at the time of the start cycle if water has filled, absence of voltage shows that the program controller is faulty, If there is power, then the motor is faulty, if the motor is humming or getting heated then there is friction on the drive, remove and clean the drive shaft.
May 02, 2013 | Washing Machines
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
I need a short program for washing and i lost the manual. i don t know how to program it
I have an AWM 5100 and the programs are printed on the outside of the detergent drawer, 1,2,3 prewash cotton, synthetic, delicates, 4 full wash,5 short wash cotton etc..this is not on your machine? Check the Whirlpool site, if no luck, reply here and I will see if I can help more..perhaps I can scan and email to you? but might not be same control options.. my machine also has a rapid wash button, which speeds any cycle.
Good luck
Jun 21, 2010 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool awm 312 goes through cycle but drum does not turn belt is ok
hi
a user manual for awm 312?
i didn't find on net.
thanks
Mar 14, 2010 | Whirlpool Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool awm 221 washer
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool 6th sense front loader awm 8121
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
252 people viewed this question
Top Washing Machines Experts
