Question about GN Netcom GN 8110-USB (706487000020) Audio Input
Hi i am using windows 7 and GN Netcom GN 8110-USB drivers are not getting installed
According to a Jabra Rep, there is a hardware update available that needs to be run on an XP machine, prior to installing the headset on Windows 7.
You can get the link by calling the Jabra Technical Support Team at (866) 697-8757.
Posted on Mar 13, 2012
  • 122 Answers
HELLO, I THINK THE PROBLEM IS FROM YOUR WINDOOWS, IS EITHER YOUR WINDOWS IS NOT GENUIE OR THE SOFTWARE IS NOT PROPERLY INSTALLED, AND IF IT IS PROPERLY INSTALLED, ALL YOU HAVE TO DO IS TO REINSTALL THE WINDOWS AND TRY INSTALLING THE SOFTWARE AGAIN, I BELIEVE THAT WILL WORK.
Posted on Mar 23, 2011
How to make a GN 9350 unit work with Windows 7?
Skip dealing with it. You don't need the $110 BS "upgrade" as this is a driver issue. Jabra could very well have provided a downloadable and install-able driver for the GN 9350 that would work perfectly, and tell windows not to use the unsigned USB driver in the headset firmware.
Fortunately there is a quick-fix workaround... it is only a little bit of a pain (and proof that their $110 firmware upgrade is not necessary).
When you want to use the jabra with Win7:
1. Plug it into your computer via USB.
2. Go to your playback devices menu (right-click the speaker icon in the system-tray)
3. Set the GN 9350 as the default device for recording and playback.
(right-click, and test, should error (couln't play test tone)
4. unplug the power to the reciever/base.
5. wait 10 seconds.
6. plug it back in.
7. may need to set it as the default again, but you should be good for a while, just don't switch back and forth too much between computer and phone.
Oct 03, 2011 | GN Netcom GN 9350 Wireless Headset
I have the same problem with the installation of GN8120 and windows 7. just do not work. With XP was no problems.
go to gnnwtcom websites and go to support download the driver update software and run it in windows xp machine with headset connected. whatever error msg you see just ignore then connect it in your windows 7 should work perfectly....
Jun 09, 2011 | GN Netcom GN 8120 USB Headset
Hi, I have a GN8120 USB and want to use it with Windows 7. With Windows Xp it was installed automatically. With Windows 7 I got an error during installation. Do you have a solution for that? Thanks Best...
To enable Windows 7 support for the GN8120 USB headset, you need to make sure it's it has Firmware Version 11.0 or newer. The version 11.0 firmware updater can be found at http://www.jabra.com/sites/Jabra/GNimages/Software updates/GN8120_Update_790.zip or http://headsetplus.com/PDF/GN8120_Update_790.zip. Other headset updates and more info can be found at http://headsetplus.com/faqdesk44/faqdesk_info.html. Note that the firmware update must be performed under Windows XP, not Windows 7.
May 20, 2011 | GN Netcom GN 8120 USB Headset
I updated to windows 7 and now i need a driver for my headset
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
don
Feb 21, 2011 | GN Netcom GN 8110-USB (706487000020) Audio...
I have Vista as OS, when I plug in the GN 8110 USB. There is an installation process started, but in the set-up there is no audio device to be seen.
so far i have not found a single driver or program package for this device. the reason for this is the device was specifically designed for windows xp and running it in compatibility mode might fix it temporarily, but might cause issues elsewhere. if you choose to do so, you can :
  • Assuming you have the Installation program on the desktop(if it is on the CD then you will need to copy the contents of the CD to a folder on the desktop. create a new folder and drag and drop the files ito it.), right click on the program setup and select properties. in the properties tab there is a compatibility tab.
  • On the compatibility tab select the check-box for run this program in compatibility mode for Windows XP (Service Pack 3). then make sure the check boxes for disable windows themes and run this program as an administrator are checked.
  • click apply and then click ok. run the program now
this should work, but if not.........
the alternative is to buy the updated version. i have found several on the internet for really inexpensive prices to include this one: http://cgi.ebay.com/JABRA-GN-NETCOM-6299-829-105-BIZ-620-DUO-USB-HEADSET-/180542469641?pt=LH_DefaultDomain_0&hash=item2a092b7609#ht_1531wt_905
this is the update for your model. i would suggest this one because windows vista/windows 7 supports it.
If you have any problems let me know and please leave positive feedback for me.
Jethro
Feb 01, 2011 | GN Netcom GN 8110-USB (706487000020) Audio...
Hi I need the device driver for GN8110 USB digital audio adapter
I think you can use this: http://www.nec.com.au/sp30/driver.htm
In case it does not work, try a driver finder program:
http://www.driverfinderpro.com/
Feb 21, 2010 | GN Netcom GN 8110-USB (706487000020) Audio...
Pairing GN Netcom GN 6210 with my iphone
Press the talk button on the 6210 Device and hold it until you here (2) faint beeps. Walla! (poor design and documentation?)
Mar 08, 2008 | GN Netcom GN-6210 Consumer Headset
GN Netcom GN 8110-USB (706487000020) Audio Input Logo
2,948 people viewed this question
Top GN Netcom Televison & Video Experts
Marvin
Marvin
Are you a GN Netcom Televison and Video Expert? Answer questions, earn points and help others
