Question about Acer Aspire m5640 PC Desktop
Dear sir. I have Acer Aspire M5640 Pc. I try to install Win vista . normaly Vista Dvd is booting.. and 2nd step masage will be coming load drivers - No device drivers were found . Make sure that the installation media contain the correct drivers and then click ok. Normaly my Comuter is now running contition. hdd is ok. how can i Re install Visat in my computer . what is your greate ideas? pls help me.
    Brigadier General:
  • 8,909 Answers
The rescue disc that can only be made on your laptop by your laptop contains the required drivers. The Vista DVD on has generic drivers and may have specific drivers missing.
Are you attempting a fresh install or are there fragments of an old troublesome system still there?
If there is fragments left, after checking that the rescue/restore data is no longer on the hard drive, format the drive first and try again. It should then work.
Posted on Mar 23, 2011
Sir if i load xp in in my pc(acer m5640) it shows blue screen when checking or loading setup. so plz give me solution now
That is because it is designed to run on Vista and XP is not supported with drivers etc.
The motherboard will not run because XP has no drivers for it. XP is too old!
Jan 07, 2011 | Acer Aspire m5640 PC Desktop
Acer aspire 6530 will not run windows vista, will not allow safe mode, just keeps loading files on screen then nothing! LOADED: :WINDOWS:SYSTEM32:DRIVERS:FILEINFO.SYS (loading files message but with a...
When your computer is first booting, try tapping F12 to get to the boot menu. Once there, boot from the Vista installation disk- you may need to fully reinstall windows from that point. Try doing a repair first- if that does not work, do a full reinstall.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 03, 2010 | Acer Aspire 6530-5143 Notebook PC
Aspire m5640 pc desktop 3rd master disk error. it wont load up windows vista, hoow do i fix it
try remove your harddisk cable (sata or ide cable) and insert to another port of your motherboard :)
Jul 29, 2010 | Acer Aspire m5640 PC Desktop
About installation
Hello
go here and select notebook,Aspire,Aspire 4720Z ,select your operating system(for example VISTA HOME BASIC X32)push the tab DRIVER and download the camera driver and install it.The push the tab APPLICATION and download acer webcam application and install it and it should work;)
Jan 20, 2010 | Acer Aspire 4720 Notebook
VISTA Acer Laptop (My Boss's) - Replace it with XP - Help Fast
Well just yesterday i removed vista from a lenavo desktop. When i tried with the installation cd setup it didn't allow and got a lot of beep error from the desktop. Then I got a partition manager formatted c drive and then booted through a dos bootable cd which keeps the drivers and command files in ram and then inserted xp os cd and through command prompt started the xp setup by typing d:enter d:dir (got the list of files and folders then typed d:setup and xp setup started and installed later I got all the relevant drivers from the net. Its not easy to get drivers from net.
Nov 11, 2009 | Acer Aspire 5535-5050 Notebook
Cuando instalo el programa de vista me dice que se perdio el cd/dvd device driver
you have to download the drivers for that expecific windows vista on the internet, find your model of the cd/dvd and look for the drivers that work with vista
Aug 11, 2009 | Acer Aspire m5640 PC Desktop
Acer Aspire M5640 came with Vista but want to go to XP. How do we do this? Acer Aspire M5640 E540A 3Gb DDR2 memory 500Gb Sata HDD GForce 80600 GS Vista Home Premium What to instead have XP Home Full on...
I would suggest going with XP Pro first off but what you need to do is get into your bios and change the boot priority to the cdrive as the first device then harddrive as second. Put your XP disc in and reboot the computer after a few moments you should see press any key to install ...... this will start you off with the install from here on follow onscreen instructions.
Onsce at windows desktop you will need to get a ton of drivers and this is were the fun comes in. Use support.intel.com for all intel devices inside the system. After that you will have to goto your device manager and see what still needs to be installed. Now you will have to hunt down the manufacures websites and go to there support page and get needed drivers.
If you need more help you may call us at the office 3868487115
Mar 17, 2009 | Acer Aspire m5640 PC Desktop
Cd/dvd drivers missing on vista 32 install
The best way to find out if you need SATA or IDE is to open the case and look. If you have gray cables about one-inch wide with a red line on one side then that is IDE. They are parallel cables. If you have anything else then it is SATA which is a serial cable. I have never been to the Acer Website but I know on Dell, HP, etc. they have a place under support and drivers that you can go. Type in your model number and download the drivers. I don't know if you have another computer to do it, but unfortunately if your restore disk do not work then that is where you will have to go...also see if you can contact someone at Acer and find out why your restore disk do not work. I have wiped my hard drive clean and I was still able to re-install the revovery disk.....Hope this helps.
Don't forget to rate this solution before you log out.
Jan 27, 2009 | Acer Aspire T690 (AST690UP820A) PC...
How to install windows vista at acer aspire 4330 LAPTOP
HELLO I AM RAVICHANDRAN FROM iRELAND, I BOUGHT THE EEE PC 900 SERIES WINXP, I GB RAM CELERON 900 PROCESSOR. NOW WIDOWS XP IS CORRPTED, WHAT CAN I DO . I HAVE A USB DVD DRIVE. HOW IS BOOT THE BOOTABLE CD. PLEASE DETAILY EXPLAIN ME STEP BY STEP
THANKS
Oct 10, 2008 | Computers & Internet
Acer Aspire m5640  PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
