Question about Juki Sewing Machines
Dear after we receive part No. HT006540000 Transistor fix in PWR PCB P/N 40030700 RU1( IRAMX20UP60A-2). We are facing a new ERROR 071 In JUKI DDL-9000A-SH with control box SC-810 display.Error 071 no any description in machine book. we have totally 10 PWR PCB P/N 40030700 Error 071. After this error appear on the display when we check the PWR P/N 40030700 RU1( IRAMX20UP60A-2) IPM module with multimeter. IPM Module out put diode is O.K. With reference to the data above I need further your grandness in this regards .kindly replay at your earliest. I well am girt full to you. Your immediate response will be appreciated Yours truly, Muhammad Nadeem A.M Electronic Master Textile Mills Ltd. (Garment Div) Mob#+92-0301-4029094
2 Suggested Answers
  • 47 Answers
SOURCE: I am looking for a owners manual for a Juki ddl 5500 machine has lots of manuals and parts for a cheaper price
Posted on Jul 24, 2009
Hi We have JUKI AMS-210D and facing problem in no display. Error code 100, 101, 104 comes we check cable J14 fuse every thing. Anyone can help.
Have you researched what the codes signify? That will give you a good clue of what's going wrong and how to address each. In your case, since you are having multiple issues, service may be a good option.
According to this link, it means a board problem:
How to solve error 100 in JUKI LK 1930 bartacking machine some time will...
Dec 17, 2016 | Juki Sewing Machines
Can I adjust the timing on my Juki TL-2010Q myself? I need realy detailed directions!
Have you replaced your needle first. Sometimes simply a new needle will do the trick. That Juki being a straight stitch only machine make it simple. When the needle reaches its lowest point and then starts back up about an eight of an inch. The point of the hook should be slightly above the eye of the needle and be directly behind the needle shaft.
Feb 02, 2016 | Juki Sewing Machines
Getting an e730 error code. machine turns on and runs for a second and then the error comes up. All cables from the motor to pcb look fine.
regarding error E730 only two way to resolve :
1- check connectors between motor and control box.
2- need to replace AC servo motor ( encoder was damaged )
best regards
Cairo - Egypt
Jul 08, 2015 | Juki DDL-8700
How to solve the err 071 of SC 810 control box of Juki
Hi Mohamed
regarding Error E 071 of SC-810 control please check :
1- thread trimmer cam correct adjusted or not.
2- there is a lot of thread into motor pulley or machine pulley.
3- if error E 071 coming immediately when turn power ON means problem inside control box, to confirm that please put working control box on machine , if error remove means problem at control box.
best regards
Mar 02, 2015 | Juki Sewing Machines
I have a Juki ams-210en that is giving me error e306 thread clamp position error. what is that and how do you fix it
hello Rick
have a good day to you
regarding JUKI machine model AMS-210EN with error E306 please check next points:
1-Needle thread clamp pulse 1-A) There is a certain obstacle in Check the mechanical block to see if there is any
Needle thread clamp position error motor fails to properly work. the mechanical block. position with a heavy load or any section caught
by something.
1-B) The driver circuit is out of order. Replace the MAIN board.
1-C)Motor defective Measure the resistance of the motor winding by means
of a circuit tester.
2-The sensor is not turned ON. 2-A) Sensor defective Check the sensor with the check program I_03.
2-B) Disconnection of connector Check CN66 of INT board.
2-C)Sensor mounting inadequate Check the operation with the check program I_08.
Jan 06, 2015 | Juki Sewing Machines
How to solve error 100 in JUKI LK-1930 bartacking machine? some time will come error 104.
Hi Indika
regarding error E100,E101,>>>> to E104 means main board was problem and need to replace ( no chance to repair ). even you check all PCB by eyes you cant find any fault , just need to replace main board with JUKI part No. : M8601-593-AA0 .
best regards
technical support ( JUKI - PEGASUS - JACK )
Jun 22, 2014 | Juki Sewing Machines
I have an error code on my juki ddl 8700-7 that reads e811
hi there
may i know control model ? any way E811 means :
1- over voltage when voltage higher than guaranteed one is inputted ( please check wheter the applied power voltage is higher than te rated voltag ( plus ) 10% or more.
2 - Check whether 110V/220V changeover switch is improperly set.
3 - if 400 volt is input means POWER P.C.B is broken maybe repair or need to change.
best regards
ashraf abozid
Dec 01, 2010 | Juki DDL-8700
Some times Error-2 & some times error-4.Our model is JUKI8500-7.Control box model is SV500 series. Pls advice the soluations. Regards, Kailash
hi there
1- your control box model is SC-500 not SV500, juki didn't made sv never ever
2- there is no error 2 just error 3 and error 4 both means there's problem with synchronizer which installed behaind handwheel first try to clean it by dray spray maby there's some oil or dust arround it. if error still coming change the senchronyzer with new one
best regards
ashraf abozid
Sep 03, 2010 | Juki DDL-8700
Sewing Machines Logo
55 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
