Question about Electrolux EI30BM55H Microwave Oven
My touch panel on the door does not work. any
My touch panel on the door does not work. any suggestions?
    President:
  • 1,654 Answers
When these go out the usually have to be replaced, there are no replaceable parts for them. Usually you have a stuck button and this is from pushing it too hard, or cleaning fluid gets into the pad and the problem is the whole touch pad gets ruined and has to be replaced. Unless your familair with small appliance repair I would have a tech look at this.
Posted on Mar 23, 2011
    Brigadier General:
  • 8,909 Answers
Usually F3 will be in the display if the control board is faulty so I expect you will only need a touch panel.
www.espares.co.uk or www.partstore.com if you are not UK.
My microwave oven will not turn on.
touch panels do go faulty. Claim on the warranty.
Jun 19, 2016 | Sharp R-331ZS Stainless Steel Mid-Size...
My microwave LG MB-2341BR is not functioning as the touch panel not working. The start touch is not working. Do we get touch panel replacement now?
I being an experienced technician all I do is get micro buttons such as used in television set .I carefully apply minimal hot air from a hair dyer to the touch panel in a clean environment then strip the adhesive touch panel to check the wire ring that tress back to the pcb that is just beneath the touch panel. yo have to locate common and the wire responsible for touch, then drill a small hole where the micro button will sit solder to wires on the button then carefully solder them on the board.now make sure the button is on the same level with the surface before you return the adhesive touch panel make sure the button sits well then from beneath apply hot glue please don't use super glue if you don't understand I will send you pictures.
Jun 16, 2016 | LG Microwave Ovens
Touch Screen Not Working. Have cleaned the ribbon cable contacts and still the screen lights up showing the buttons but nothing on the touch pad works. If not the ribbon cable being dirty, I guess i
Most of the time the panel buttons stop working because grease gets between the outer panel and the contacts underneath. Disassemble the door and if you need to carefully peel back the outer panel, use some paper towels to remove the heavy grease, then using a Q-tip and some rubbing alcohol clean the back of the panel and the surface contacts on the board, then re-assemble.
Dec 26, 2014 | In Microwave Ovens
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Benjamin
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
On button no longer works
Without your brand and model number, it's hard to give specific guidance, but when a microwave won't start, the first suspect is a bad door switch or door switch mount. See this file.
You mentioned that you clean the touch panel. I hope that a cleaning spray was not sprayed directly on the controls or on the oven. That's a big killer of controls.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Contract us if you need more free advice.
Jan 31, 2010 | Sharp R-120D Microwave Oven
Maytag mmv5000bdw Touch panel works intermittently The panel will not respond to the touch. Work around include: 1. closing the microwave door hard and trying again. 2. unplugging the microwave and trying...
If nothing works, it sounds like you didn't get the cable inserted properly. It should fit into a connector which carries signals to the microwave's control components. These connectors usually pullup, you insert the cable, and push the connector back down.
Oct 14, 2009 | Maytag MMV5000 Microwave Oven
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Mar 18, 2009 | LG LMVM2055 Convection/Microwave Oven
Electrolux EI30BM55H Microwave Oven Logo
274 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
