Question about Sta Rite Tune Up Kit Dyn Glas Dyna Max ()
How to remove impeller seal - Sta Rite Tune Up Kit Dyn Glas Dyna Max ()
  • 310 Answers
Remove v-clamp from wet end.
Remove diffuser from wet-end using a flat blade screwdriver.
Remove impeller screw by turning clock-wise(this is a reverse threaded screw (some impellers dont have an impeller screw))
Remove back end of motor using a 1/4" hex driver.
Secure rear end of motor shaft by slipping a 7/16" open face wrench into rear electrical compartment
While securing the shaft, turn the impeller counter clockwise until its off.
Remove seal halfs and replace with identical seal.
Reverse to finish the install
Posted on Mar 23, 2011
How do I remove impeller from 2.0hp Maxi Flow pump
The instruction below may vary slightly for your model pump, but should give you the info you need to get the impeller off and get to the seal... To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under the thermal overload switch and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Dec 13, 2014 | Pool & Spa
Winding noise with some water leaking from the motor seal. Water still flowing but sounds laborous.
The shaft seal more likely than not needs to be replaced. If your shaft seal has been leaking for any length of time, the bearings could be damaged and this should be replaced. The whisperflow uses a PS1000 shaft seal and is fairly easy to replace (most seals available online or at most swimming pool retail stores). It is best advised not to run the pump until you have had this inspected by a licensed pool technician or have changed out the seal.
1) Make sure breaker/power to pump is off. 2) Remove the six bolts holding the wet end to the seal plate. 3) Remove the diffuser to expose the impeller. 4) Remove the screw in the middle of the impeller by turning clockwise (left hand threads). 5) Remove the dust cap at the rear of the motor and use a wrench to hold the shaft while you remove the impeller by turning counterclockwise. 6) Once the impeller is off, remove the four bolts holding the seal plate to the motor. 7) Press the old seal out of the seal plate and clean it thoroughly. Remove the ceramic part of the seal from the impeller and clean it thoroughly as well. 8) Apply a thin coat of lube (I prefer Magic Lube or Lube Tube) to the seal plate and impeller where the new seal will go. 9) Remove the new PS1000 shaft seal from the box (being careful *NOT* to touch the ceramic or carbon face with your fingers), press the metal part into the seal plate carefully, try not to bend the metal and make sure its completely seated against the seal plate. 10) You can now install the seal plate back onto the motor and secure with four bolts. Press the ceramic part into the impeller, use cardboard or paper between your fingers and the ceramic face. 11) Once you have seated the seal into the impeller, hold the motor shaft and thread the impeller on until snug, then reinstall the stainless screw, remember it is left hand thread so you'll have to turn it counterclockwise. 12) Reinstall the diffuser over the impeller and then install the wet end onto the seal plate using the six bolts, don't overtighten them.
Check the pump for operation and you should be good to go!
Dec 07, 2010 | Pentair 011515 WhisperFlo FullRated Energy...
I am trying to remove the impeller on a SP158015, to change the leaking seal to the motor shaft. Is the impeller threaded?
Oct 16, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Pump seal is leaking water. I removed the screws holding the pump together. How do I remove the impellor to get at the seal?
This is from one of my previous posts, may be some extra steps, but should cover what you need... Turn off the electric first. Now split the pump in two by removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing). Once you remove the clamp or bolts, the motor with seal plate, diffuser, and Impeller can all be pulled back away from the pump. Then disconnect the electrical from the motor and you can pull the motor with the seal plate, and impeller all the way out and work on it. To get to the impeller, you need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under the thermal overload switch, or removing the capacitor for even easier access. Once you've locked the shaft, you can just unscrew impeller. If the impeller has a bolt or screw in the middle remove that first. this screw will be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure to replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white ceramic, and black graphite surfaces 100% free of any dirt, grease, etc while working with them. Installation is pretty much just the reverse. Install half the seal into the seal plate. Install the seal plate onto motor and bolt into place. Install other half of seal onto shaft. Screw impeller onto shaft and install screw (if one was there to start with) in center of impeller (reverse thread). install diffuser over impeller make sure it is centered and doesn't rub the impeller hub. Install new diffuser and valute o-rings. Hookup wiring before re-attaching to rest of pump. Clamp or bolt back together. Pour plenty of water into pot to prime and flip the motor on for a sec or two. Pour some more water. Install pot lid. You should be good to go. Keep in mind there are many different pumps and some variations to the above instructions, but the above should cover most situations. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 03, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
How do I remove existing motor and replace it with a new one ? Hayward 2.0 hp # SP2615X20 Thank you
Oct 02, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Pool sweep pump stuck and will not turn.Binding on impeller to rubber seal.How to disassemble remove impeller and seal.
Sounds like maybe your motor bearing are going bad, or have already seized up. When you say "rubber seal" are you referring to the rubber portion of the shaft seal? Either way, to remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. If the bearings are seized up then you'll have to replace the motor, or have it rebuilt.
Sep 18, 2010 | Pentair Letro Booster Pump IMPELLER LA02L
How do I remove the pb460 booster pump in order to install the new one? Does the water have to be turned off from the pool?
You are trying to remove the pump so you can replace the impeller correct?
To remove the impeller you do not need to remove the whole pump. Turn off the electric first. Then just remove the several bolts and separate the back half from the front. Then disconnect the electrical from the motor and your can pull the motor with the seal plate, and impeller all the way out and work on it. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white and black ceramic surfaces 100% free of any dirt, grease, etc while working with them
Sep 17, 2010 | Polaris Pb460 Polaris Booster Pump...
How to install the motot?
Turn off the electric first. Now split the pump in two by removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing). Once you remove the clamp or bolts, the motor with seal plate and impeller and diffuser can all be pulled back away from the pump. You need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. Then disconnect the electrical from the motor and your can pull the motor with the seal plate, and impeller all the way out and work on it. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure to replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white and black ceramic surfaces 100% free of any dirt, grease, etc while working with them. Installation is pretty much just the reverse. Install half the seal into the seal plate. Install the seal plate onto motor and bolt into place. Install other half of seal onto shaft. Screw impeller onto shaft and install screw (if one was there to start with) in center of impeller (reverse thread). install diffuser over impeller make sure it is centered and doesn't rub the impeller hub. Install new diffuser and valute o-rings. Hookup wiring before re-attaching to rest of pump. Clamp or bolt back together. Pour plenty of water into pot to prime and flip the motor on for a sec or two. Pour some more water. Install pot lid. You should be good to go. Keep in mind there are many different pumps and some variations to the above instructions, but the above should cover most situations. if something doesn't sound right let me know by commenting on this post, or sending email and I'd be glad to clarify. Good Luck!
Aug 03, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
Need to know how to remove the impeller.
remove back cover of mtr. hold shaft with large screw drver. remember some modles have rev. threads
Dec 08, 2009 | Jacuzzi Impeller, L - 3/4 H.P
1hp whisperflow pump, seal change. How?
Make sure breaker/power to pump is off. Remove the six bolts holding the wet end to the seal plate. Remove the diffuser to expose the impeller. Remove the screw in the middle of the impeller by turning clockwise (left hand threads). Remove the dust cap at the rear of the motor and use a wrench to hold the shaft while you remove the impeller by turning counterclockwise. Once the impeller is off, remove the four bolts holding the seal plate to the motor. Press the old seal out of the seal plate and clean it thoroughly. Remove the ceramic part of the seal from the impeller and clean it thoroughly as well. Apply a thin coat of lube to the seal plate and impeller where the new seal will go. Remove the new PS1000 shaft seal from the box (being careful not to touch the ceramic or carbon face with your fingers), press the metal part into the seal plate carefully, try not to bend the metal and make sure its completely seated against the seal plate. You can now install the seal plate back onto the motor and secure with four bolts. Press the ceramic part into the impeller, use cardboard or paper between your fingers and the ceramic face. Once you have seated the seal into the impeller, hold the motor shaft and thread the impeller on until snug, then reinstall the stainless screw, remember it is left hand thread so you'll have to turn it counterclockwise. Reinstall the diffuser over the impeller and then install the wet end onto the seal plate using the six bolts, don't overtighten them.
It is a good idea to replace the tank o-ring when taking to pump apart, but if the o-rings are in good condition, just apply a light coat of lube and reuse them.
This is a general guide for replacing a seal, if you have trouble removing the impeller, you may need an impeller wrench and a tool to hold the motor shaft.
I hope this helps, if you have any specific questions, email me at mail@leisurepoolservice.com
Oct 28, 2009 | Pentair Pool & Spa
Sta Rite Tune Up Kit  Dyn Glas  Dyna Max () Logo
321 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
