Question about Exabyte Refurbished 200 SLOTS 1 MAMMOTH DRIVE (x20001) Tape Drive
How can i remove a disk in the cd rom - Exabyte Refurbished 200 SLOTS 1 MAMMOTH DRIVE (x20001) Tape Drive
  • 187 Answers
Look for the small button in front of your CD-ROM and press that one. Your CD-ROM should now open.
Thanks & Regards,
(-_-)
Posted on Mar 23, 2011
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
How to replace compaq evo cd/dvd disk drive
hi.
open yr desktop cassing then u will see yr cd/dvd rom. then find for button to remove cd/dvd rom then pull tht tht boten and pull up yr cd rom.
new cd rom you must set jumper setting to slave then connect all cd rom cable. on yr system ten see yr cd rom will auto place in my computer.
regards
Feb 21, 2011 | Compaq Evo D510 PC Desktop
The computer does not work when the CD-ROM is connected
the jumper may not be set it up correctly to set it the instructions are 1. switch off the computer safely 2. remove power cord then open cabin-ate 4. set jumper for hard disk as master 5. set jumper for CD-ROM as slave note instruction are given in label of hard disk and CD ROM don't forget to give vote bye bye enjoy
Dec 26, 2010 | Computers & Internet
Netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair this file by starting windows setup using...
Put the original setup CD-ROM into your CD-drive.
Restart the computer.
Tell it to "boot" from the disk in the CD-drive.
Choose "repair an existing Windows installation",
and let it fix the problem.
Remove the CD-ROM disk.
Restart your (repaired) computer.
Oct 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
Need to find out how to install my memorex double layer 16x
Ok here is what you need to do. Open the box that the driver came in and also the side panel of your computer. Remove the cables that are attached to the current CD-ROM drive and if you need to unscrew the screws that are holding the CD-ROM drive in place which you'll need a phillips screw driver for. Remove the old CD-ROM and put in the new one and reconnect the cables to the new one. If an installation disk came with it then put that in the CD-ROM drive and install whatever is on that disk. Afterwards you should be ready to go. If you need anything else please let me know!
Apr 05, 2009 | Computers & Internet
Cd rom does not recognize any disk i have atapi 56max
the lens inside the cd rom wil hav to be cleaned
then it wil detect
if the problem still remains then u have to replace the lens inside the cd rom
Mar 07, 2009 | CyberDrive 56X CDROM IDE ATAPI (CYBER56X)...
I can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Jan 27, 2009 | HP Compaq Evo Notebook N1020v PC Notebook
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
USB flash disk not working
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Jan 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
Top Exabyte Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Exabyte Computer and Internet Expert? Answer questions, earn points and help others
