Question about LG WM-2277HW Front Load Washer
I have a low water use LG front loader and white synthetics are turned grey no matter what cycle I use and even when I only place them in with other white or pale colours. It is especially bad with delicates.
    President:
  • 1,654 Answers
Have you checked to make sure your not getting water syphoning back out of the drain hose into the tub? this is the usually cause for this. Dirty water is getting back in. The hose should be at least as high as the back of the machine with a elbow on it or an anti syphoning kit should be used.
Posted on Mar 23, 2011
Hi, I have a LG Tromm WD-14331AD. At the start of the wash cycle, water will dispense, but not a lot. When spinning, there is hardly any water in the drum and water just stops dispensing.
A front loader only uses a very small amt of water. That's the point of front loaders. Make sure u only use a very small amt of detergent also. And use white vinegar in place of fabric softener. If washer is slow to fill you can check the filters in the supply lines. Take the water lines off the back of the washer and check the filters in the washer
Jan 01, 2017 | LG Washing Machines
Have a 4 day old Samsung Front Loader WF330ANB. It is leaving grey spots on my white towels. I do not use Fabric softener and I do not use the HE detergent over the Max fill line. Both Samsung and...
your using to much soap. use 1 tablespoon of detergent. too much soap will cause spots. depending on which cycle your using . might not be enough water on the rinse cycle. nothing wrong with your washer. i'm a certified samsung tech. hope this helps
Jun 03, 2011 | Samsung WF330ANB Washer
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
HOW DO i GET MY WHITES WHITER?
Use an oxygen-based bleach first--if not much better, try a chlorine-based bleach. Hot water works better than cold water. Try using a different detergent as well. Do these things one at a time to find which produces superior results. Hope this helps!
May 13, 2010 | LG WM1814CW Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Whites don't get clean in front loading washing machine
I have the same problem and I'm really aggrevated that I paid alot of $$ for something that doesn't do the job it was purchased to do! I'm going to look at replacing it with a top loader. I think LG should take responsibility for selling a bad product.
Jul 15, 2009 | LG WM1814CW Front Load Washer
LG front loader - shower water filling up machine
your drain should have a backflow device in it. This can be very dangerous, you need a professional plumber ASAP.
Feb 17, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Make sure you are washing at the correct temp, and that you have the correct prog selected for what you are washing. and that you have suficient powder and or detergent in. Check to see if the water is getting hot, because if it is not , then the heater may not be working, and then your clothes will not be clean.
Hope this helps with your prob.
Plz rate my solution.
Thanks.
Jan 03, 2009 | LG WM-2277HW Front Load Washer
LG washer (WM0532HW) whites turning dingy grey
I too have a front load washer. The problem is that it's not washing off all the soap suds. Try this. After a complete cycle, soak the clean clothes in a container w/ water and you'll see there's still soap suds coming out of the clothes. I tried running it several wash cycles and there was still soap left on the clothes. I think, it's mfg defect. We should all complain to the maker of the machines.
Jul 25, 2008 | Washing Machines
White Clothes even with bleach and hot water don't get clean???
i have used everything to solve this exact problem!  I have to say the best detergent or bleach i have used in the lg..is the purex with bleach for colours it seems to work better than anything ive used...spent a fortune to have to soak my whites before putting them in this washer.  I must say im disappointed..
May 06, 2007 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
104 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
