Question about Epson Stylus NX100 InkJet Printer
I have an Epson Stylus NX100. It was working fine yesterday. Now when I try to print it says it can't recognize the ink cartridges. I'm using the recommended ink cartridges for the printer. I've tried cleaning the printer heads and even uninstalling it and restarting the printer back up. Still telling me it doesn't recognize the cartridges... any ideas?
  • 158 Answers
Try to restart the print spooler under services.msc
start>run>services.msc look for print spooler then restart it
Posted on Mar 23, 2011
I have a new laptop computer. It will recognize my epson nx100 printer, but it won't print.
Install Epson printer software from Disk if not disk then go to Epson website and locate your printer and download.
Mar 19, 2014 | Epson Stylus NX100 InkJet Printer
General Error message on a Epson Stylus NX100
Incase you have used a compatible cartridge , they may not work at times . Insert the old cartridge and check , if it prints ( even though partially ) . The problem could bein the cartrige or the fitting of the same .
Dec 20, 2012 | Epson Stylus NX100 Multifunction Printer...
Installed new epson ink. does not recognize cartridge
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 08, 2010 | Epson Stylus NX100 InkJet Printer
I have an epson stylus NX100 and i just put brand new black ink in it recently i printed two pages max i went back to use it and it says that my black ink has expanded and i have to buy a new one? what...
***hi there,ill be willing to help you on that. ****
try to reseat the cartridges first to charge it again, reseat means Remove and reInstall the Cartridges. after doing that and still the same issue, and you have an extra set, try to load another brand new ink,just to isolate if it is the ink thats causing the problem, if the same issue persist, its not the ink that you bought, its the printer already, the printer is broken, call epson if it is still covered by 1 yr warranty, 1 yr with in date of purchase. they will send you a replacement printer.
1. Turn on the Epson Stylus NX100 Series.
If a cartridge is expended, the ink light on the control panel stays on. You must replace the cartridge to be able to print.
If the ink light is flashing, a cartridge is low on ink; replacement is recommended.
2. Open the scanner and prop it up with its support
3. Press the nx100_tx100_ug.1.93.5.jpg Stop button. The print head moves to the nx100_tx100_ug.1.93.6.jpg position to indicate which cartridge is low or expended.
4. Press the nx100_tx100_ug.1.93.8.jpg Stop button again. If another cartridge is low or expended, it moves to the nx100_tx100_ug.1.93.9.jpg position. Press the nx100_tx100_ug.1.93.10.jpg Stop button again to see if more cartridges are expended. If no other cartridges are low or expended, the print head moves to the replacement position on the right. 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
7Remove the cartridge from the package
8. Remove the yellow tape from the bottom of the cartridge.
9. reInsert the new cartridge into the holder and push it down until it clicks into place. 10. Once you replace all the necessary cartridges, lift the scanner slightly, release its support, and lower the scanner.. 11. Press the nx100_tx100_ug.1.93.18.jpg Stop button to begin charging the ink. This takes about 1 1/2 minutes. When the nx100_tx100_ug.1.93.19.jpg On light stops flashing and remains on, ink charging is finished. Caution:
Never turn off the Epson Stylus NX100 Series while ink is charging or you’ll waste ink.
Jan 21, 2010 | Epson Stylus NX100 InkJet Printer
Trying to replace the black inck cartridge and cannot get the cartridge holder to stop at a position for me to pull out the old cartridge and insert the new cartridg. I've have an Epson Stylus NX1000...
Found this on the Web for Your Printer. You can download the Manual from Epson.
If you find this helpful, pls rate me.
http://files.support.epson.com/pdf/nx100_/nx100_qr.pdf
Checking the Print Head Nozzles
If your printouts are faint or have gaps in them, some of the nozzles in the print
head may be clogged or ink may be running low in one or more of the ink
cartridges. Follow the steps below to check the print head nozzles.
1. Load letter-size paper in the sheet feeder.
2. Turn off the NX100 Series.
3. Hold down the y Stop button as you press the P On button to turn the
NX100 Series back on. Hold down both buttons until the P On light begins
to flash, then release the buttons.
Cleaning the Print Head 21
4. Check the nozzle check pattern that prints to see if there are gaps in the lines.
5. If there are no gaps, the print head is clean. If there are gaps or the pattern is
faint, clean the print head as described in the next section.
If print quality has declined and the nozzle check pattern indicates clogged
nozzles, you can clean the print head. Print head cleaning uses ink, so clean it only
if necessary.
Note:
You cannot clean the print head if an ink cartridge is expended, and you may not be able
to clean it when a cartridge is low. You must replace the cartridge first (see page 23).
1. Make sure the NX100 Series is on and the B ink light is off.
2. Hold down the y Stop button for three seconds to start the cleaning cycle,
which lasts around one minute.
Caution:
Never turn off the NX100 Series during head cleaning or you may damage it.
3. When the P On light stops flashing, run a nozzle check (as described on
page 20) to verify that the print head is clean.
4. If there are still gaps or lines, or the test patterns are faint, run another
cleaning cycle and check the nozzles again.
Note:
If you don’t see any improvement after cleaning the print head two times, turn off your
NX100 Series and wait at least six hours to let any dried ink soften. Then try cleaning
the print head again. If quality does not improve, one of the ink cartridges may need to
be replaced. If that doesn’t help, contact Epson as described on page 31.
If you do not use your NX100 Series often, it is a good idea to print a few pages at least
once a month to maintain good print quality.
Good Luck and Please rate me.
Jan 13, 2010 | Epson Office Equipment & Supplies
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Nov 17, 2009 | Epson Office Equipment & Supplies
Computer says black ink is low. Ink light is flashing on Epson Stylus NX100. When I hit stop button to begin replacement it wont move cartridge
2. Open the scanner and prop it up with its support.
3. Press the Stop button. The print head moves to the position to indicate which cartridge is low or expended.
4. Press the Stop button again.
If another cartridge is low or expended, it moves to the position. Press the Stop button again to see if more cartridges are expended.
6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
9. Insert the new cartridge into the holder and push it down until it clicks into place
11. Press the Stop button to begin charging the ink. This takes about 1 1/2 minutes.
When the On light stops flashing and remains on, ink charging is finished.
Caution:
If the ink light flashes, press the Stop button and press down all the cartridges securely.
Jul 13, 2009 | Epson Stylus NX100 InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Service required error
Try unplugging it for an hour first.
Thanks,
Lee
Jun 18, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
Epson Stylus NX100 InkJet Printer Logo
342 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
