Question about ViewSonic Computers & Internet
Hi i have model VS 11372, 19 inch jan2007 , 2 months back i changed the power card on the tft monitor , as the display had gone bad,, experiencing same trouble , pls advise, its too soon for this to reoccur, , the problem is not continous , on and off .. where is the problem , pls advise
  • 11,361 Answers
Did you check the caps on the power supply/inverter board and voltages (this board is known to have bad caps problem). Worst case will be the lamp assemblies. You will need lamps to test the output of the inverter.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA903B/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 23, 2011
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
Gateway fpd1760 tft lcd color monitor i not warking
- isolate the problem first by checking all the cables for any bent pins and loose wire/ connections - unplug the lcd monitor and try to get a spare computer to check if its your computer's video card or the lcd monitor - if lcd will give display using a different computer it only means there's something wrong in the computer's video card - if lcd will not give display using a different computer it only means lcd had gone bad and needs to be replaced.
thanks.
Jan 03, 2011 | Gateway FPD1760 Monitor
I have a new Samsung 24'' LCD Monitor. I have alot of distortion, almost like a waving effect. Any patches to fix this?
hi friend try this:
Monitor Problems:
THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
- Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician.
COMPUTER BOOTS, BUT DISPLAYS “JUNK” ON THE SCREEN
- It may be that the display card is defective. Try a different card. If it works the first card may be bad.
- Try the suspected bad card on another computer. If it displays the same thing it is conclusive that the card is bad.
DISPLAY IS DIM, OVERLY BRIGHT, OR BLURRY, OR UNPLEASANT.DISPLAY IS OFF CENTER. LEFT OR RIGHT SIDE OF MONITOR IS OBSCURED.
- Try adjusting the control knobs located on either the front or back of the monitor. It maybe necessary o open the monitors casing to get the proper adjustment controls. In this case be very careful because there are high voltages in the monitor.
THE VIDEO DISPLAY FADES AND BRIGHTENS, OR IS WARY.
- The voltage may be fluctuating due to so many appliances or electric devices on he same branch circuit.
- Turn off other appliances and peripherals, such as printers, external modem, refrigerator, microwave oven, transformer, etc. and see if that solves the problem. If the problem persists, try swapping out the display cards. If changing the monitor solved the problem, repair or replace the monitor.
IMAGE IS NOT STRAIGHT ACROSS THE SCREEN
- If the monitor is still under warranty, bring it back to the dealer for adjustment. If the you want to do it your self, bare in mind that this is potentially dangerous procedure because it must be done while he monitor is on and there is very high voltages around the picture tube.
Apr 01, 2009 | Samsung SyncMaster T240HD 24" TFT LCD...
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
Hi I am fairly good with computers but i dont know how to fix this problem. My advent 7113 laptop turns on the power light comes on and they the fan starts but am not sure if the harddisk boots. Then...
It sounds like Either the onboard video card or the LCD controller has gone bad. To verify which one connect a monitor to the VGA adapter on the back of the Laptop. You may also have to hit a key combination to swap displays (Usually <Fn> + <F5> but may be different the keys usually have an offset that indicates its function.
If the Monitor displays the same black and white anomaly then the vid card went bad, if it displays a normal screen your LCD controller is faulty.
Either problem would likely need service from an experienced technician
Hope this helps
Dave
Nov 07, 2008 | Computers & Internet
HP1730 TFT monitor not powering on
There are multiple circuits for this model. I suspect your model is PE1237. If so this model frequently has bad solder connections at the AC socket. Also capacitor 2119 or capacitors 2041 & 2031 can cause no power up. They normally are bulging if bad.
If your model is PE1238 (BenQ), you may see bulging capacitors in the power supply.(1000uf/25v)
Monitor Mike
Sep 18, 2008 | HP Serial adapter (17302A)
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
57 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
