I just Got a TV with no remote, unfortunately it seems only work with Remote since there's only a power button. How can I turn it on ? Only the red lamp is on when I push the power button.
  • 158 Answers
Try to buy a universal remote if thats the case
Posted on Mar 23, 2011
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
Need code for cello tv got no volume control for sky+hd
Hi, Cheri Torres with DISH Network Customer Service here. I unfortunately did not find any codes for a Cello TV. You can try running a power scan in order to find the correct code for your TV, I will list here for you the instructions. I hope this helps and if you have any further questions or concerns feel free to email me at Cheri.Torres@Dishnetwork.com.
Instructions for running a power scan
  1. Press and hold down the TV mode button until all other Mode buttons light up red
  2. Press 500 on your number keypad
  3. Press the pound(#) button once.
  4. With the desired equipment on, press and hold the TV Mode button until all mode button back lights light up red.
  5. Press and release the big red Power button.
  6. Press the Up button once a second while pointing the remote at the desired equipment.(press, release, press, release)
    Note: If the code for the equipment comes up, the equipment will power off.
  7. Press the POUND (#) button as soon as the TV turns off. If the code entered is valid for the remote, the mode light flashes three times.
Feb 28, 2011 | DISH Network IR Remote Control
I cant control my AIWA TV WITH A jumbo universal control.THE CONTROL NUMBER DOES NOT WORK that is given with the instructions
Have you tried the auto-code search?
Unfortunately, you can't teach this remote new codes, so if none of the AIWA codes from the manual work, and you run through this auto-program sequence and it doesn't work, there is no other solution for your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 19, 2009 | Innovage Jumbo Remote Control
What is the code for a goodmans (portible) tv on a
I recommend trying the auto-code search to find one that works for your TV. This will search through every TV code it knows, and if none work, unfortunately it cannot be taught new codes.
  1. Turn on your TV.
I hope that helps.
Jul 21, 2009 | Innovage Jumbo Remote Control
Remote code
Hi trckynky,
I am unable to find the Duraband tv, however many times you can search fo one that will work.
Try this.
  1. Turn on TV
  2. Press and hold the TV button on the remote
  3. While holding the TV button also press and hold the power button.
  4. The light on the remote should go out and then a second later come back on.
  5. Release both buttons, the light should remain on.
  6. Aim the remote at TV and press the power button about every 5 seconds until TV turns off.
  7. Press the STOP button at bottom of remote., this will lock in the code.
  8. Use the remote to turn TV back on and test all buttons on remote to insure you have the correct code.
If the remote will work with Durabrand this is the way to find it, unfortunately the remote may not work for all TV's.
Let me know if I can assist further.
Please rate this solution.
Lone99star
Apr 23, 2009 | Durabrand DWT1905 TV
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Feb 15, 2009 | Panasonic TH-42PZ80B 42 in. HD-Ready...
SKY REMOTE
Press TV
Press and hold Select & Red until the LED blinks twice
Press TV
Type in code 0 0 6 0
press the Power button on the remote, if the TV turns off press the select button and everything should work, if the TV stays on press the TV button on the remote then the Power button again, keep doing this until the tv turns off, when it does press the Select button and all should be ok.
Feb 01, 2009 | Toshiba MR120 Remote Control
Sky remote code fo LCD LE40A456 TV
3. Press tv again
Samsung Code: 0060
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
3. Press tv again
Sony Code: 0000
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
Mar 21, 2008 | Sony KV-27V40 27" TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
