Question about Fujitsu Heating & Cooling
Hi there, water is back feeding from the air con into the house
  • Fujitsu Master
  • 12,061 Answers
Http://ezinearticles.com/?Stop-Your-Air-Conditioner-Leaking-Water&id=3620464
Hi. please find a good article on how to stop water leaking from your aircon.
searchwarp.com > ... > Home Repairs / Remodeling
above are the top reasons why they leak?
www.ehow.com > Home Maintenance & Repair -
above how to stop aircon leaks.
Posted on Mar 23, 2011
Where is the thermostat on a 2002 Chev. Cavalier with a 2.2 DOHC located?
Please see my tip at http://www.fixya.com/cars/r5929960-s_thermostat . These are generic instructions. Specific instructions from autozone.com for your car are pasted below. If you get stuck, please get back to me.
  1. If equipped with an automatic transmission, remove the exhaust manifold.
  2. Drain the cooling system.
  3. Remove the thermostat housing to water pump feed pipe bolts.
Remove the thermostat housing to water pump feed pipe.
Fig. Remove the thermostat
  • Remove the thermostat.
  • To install:
    1. Install the thermostat.
    Install the thermostat housing to water pump feed pipe.
    Fig. Install the thermostat housing to water pump feed pipe
    1. Install the thermostat housing to water pump feed pipe bolt and tighten the thermostat housing to water pump feed pipe bolt to 89 lb inches (10 Nm).
    2. If equipped with an automatic transmission, install the exhaust manifold.
    3. Fill the cooling system.
    Nov 23, 2010 | 2002 Chevrolet Cavalier Coupe
    How to install thermostat
    from autozone.com
    2.2L Engine
    1. If equipped with an automatic transaxle, remove the exhaust manifold, as outlined in this section.
    4. Remove the thermostat housing to water pump feed pipe.
    1. Fig. Thermostat mounting-2.2L engine
    2. Remove the thermostat.
    To install:
    2. Install the thermostat housing to water pump feed pipe.
    3. Install the thermostat housing to water pump feed pipe bolt. Tighten the thermostat housing to water pump feed pipe bolt to 89 inch lbs. (10 Nm).
    4. If equipped with an automatic transaxle, install the exhaust manifold, as outlined in this section.
    5. Fill the cooling system.
    3.1L Engines
    1. Disconnect the negative battery cable.
    2. Drain the cooling system to a level below the thermostat housing.
    3. Remove the air cleaner assembly.
    4. Disconnect the surge tank line from the thermostat housing.
    5. Remove thermostat housing-to-intake manifold attaching bolt and nut, then remove the housing.
    6. Remove the thermostat.
    To install:
    1. Clean all gasket surfaces completely.
    2. Insert the thermostat in the intake manifold.
    3. Attach the thermostat housing to the intake manifold.
    4. Install the mounting bolt and nut. Tighten to 18 ft. lbs. (25 Nm).
    5. Install the air cleaner assembly.
    6. Connect the surge tank line to thermostat housing.
    7. Refill the cooling system.
    8. Connect the negative battery cable, remove the radiator cap, then start the engine. Allow the engine to run with radiator cap removed, until the upper radiator hose becomes hot (thermostat open). With the engine idling, add coolant to the radiator until the level is up to the bottom of the filler neck.
    9. Install the radiator cap, making sure the arrows line up with the overflow tube.
    Sep 25, 2010 | 2003 Pontiac Grand Am
    How long does it take to change a water pump in a 2002 SL Saturn
    Hi. Normal installation would take 45 to 1 hour depends on your expertise. Here's the procedure on how to replace the power pump.
    • TOOLS REQUIRED
    • J-43651 Water Pump Sprocket Holding Tool
    REMOVAL
    1. Disconnect negative battery cable.
    2. Remove air inlet tube and air cleaner assembly. Refer to "Air Cleaner Assembly Removal".
    3. Drain coolant.
    1. Remove exhaust manifold heat shield. IMPORTANT: Twist water feed pipe while pulling to remove it from water pump.
    1. Remove thermostat and water feed assembly bolts.
    1. Remove water pump sprocket access plate from front cover.
    1. Install J-43651 water pump sprocket holding tool. IMPORTANT: Be sure to remove retaining bolt that is accessed from front of engine block.
    1. Remove water pump retaining bolts.
    2. Remove water pump assembly.
    INSTALLATION
    NOTICE: Prior to installing the water pump read the entire procedure. Pay special attention to avoid part damage and to ensure proper sealing.
    1. Install water pump assembly.
    2. Install water pump bolts. Initially finger tighten bolts
    • Torque: 25 Nm (18 ft. lbs.)
    1. Install the water feed tube.
    2. Lubricate the feed tube O-ring with silicone gel lubricant.
    3. Install water feed tube by twisting and pushing toward water pump. Take care not to tear or damage the O-ring.
    4. Install thermostat housing to block bolts.
    • Torque: 10 Nm (89 inch lbs.)
    1. Install exhaust manifold heat shield.
    1. Install air cleaner assembly and air inlet tube. Refer to "Air Cleaner Assembly Installation".
    2. Connect negative battery cable.
    3. Add coolant.
    Aug 27, 2010 | Saturn LS Cars & Trucks
    How to change the thermostat
    Alero, Grand Am 1999-2005 Thermostat - Removal & Installation 2.2L Engine
    5. Remove the thermostat.
    To install:
    3.1L Engines
    To install:
    3.4L Engine
    1. Drain the cooling system.
    2. Remove the air cleaner.
    3. Remove exhaust crossover pipe.
    4. Disconnect the surge tank line fitting from the coolant outlet.
    5. Remove the thermostat housing to intake manifold bolts.
    6. Remove the thermostat housing outlet and thermostat
    7. Clean the mating surfaces.
    To install:
    1. Install the thermostat and housing outlet.
    2. Install the thermostat housing bolts. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
    3. Install exhaust crossover pipe.
    4. Connect the surge tank line fitting to the coolant outlet. Tighten the fittings to 15 ft. lbs. (21 Nm).
    5. Install the air cleaner.
    6. Fill the cooling system.
    7. Inspect the system for leaks.
    Hope this help (remember comment and rated this).
    Apr 04, 2010 | 1999 Oldsmobile Alero
    Why is there water dripping from the air con?
    The most probable cause is a clogged drain line.
    Also ensure your air filter and the evaporator coils are clean.
    Let us know if this helps and good luck.
    Feb 24, 2010 | Heating & Cooling
    Water dripping from air con use
    If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
    Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
    05 astra air con fault
    Hi there. The compressor will not come on unless the system is charged. There is a "low limit switch" which controls the engage voltage on the low side receiver. No charge, no engage.
    Thanks
    Paul
    Jul 11, 2009 | Heating & Cooling
    Hi, I have hot water coming through the cold water taps in the house, there is a check valve on the cold water return side of the water heater. could this be the problem? The cold water line feeding the...
    i have seen a faucet that has a valve on the end (like your pull up on the shower)back feed the hot water or yes you could have a bad ck valve dan
    Jul 23, 2008 | Heating & Cooling
    Lack of humidity
    Try the following test, ( I will resume this is a flow through humidifier)
    Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
    Option 2 is to connect the water feed tube to a Hot water source.
    Hope this helps.
    Dec 28, 2007 | Honeywell HE220A1019 Whole House...
    Heating & Cooling Logo
    103 people viewed this question
    Top Fujitsu Heating & Cooling Experts
    Fotis Papastamatiou
    AJMAL KHAN
    Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
