Sony KS-60R200A SXRD Bravia LCD Projection TV I just replaced the lamp and the TV wont turn on. The fan starts and runs for a few seconds but then it turns off. A red light (On/Standby indicator) flashes 9 times with an interval of approximately 4 seconds. The lamp is properly placed and connected and there is no "Lamp Indicator" light. Please help.
mistersony
  • 320 Answers
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Posted on Nov 10, 2008
SOURCE: 40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Posted on Oct 01, 2009
  • 418 Answers
SOURCE: My sony bravia keeps switching from
13 blinks is backlight inverter board bad.
Posted on May 06, 2010
SOURCE: sony bravia
HI I HAVE A SONY BRAVIA 55 INCH REAR PROJECTION TV MODEL NUM: KF-55E200A. 1 DAY IT JUST MADE A POP NOISE AND THE SCREEN WENT BLACK,NOW WHEN I TURN IT ON IT MAKES A BUZZING SORT OF NOISE,THE SCREEN IS BLACK AND A RED LIGHT FLASHES? WHAT DO I DO
Posted on Oct 01, 2010
scooter2387
SOURCE: Mitsubishi wont power up
Hey there, I also had a mitsubishi 72in. It did the same exact thing, we took it to the shop and they said the ''engine'' was out on it. They said it would be aprox $500 for the part and $200 for labor. We told them thats more more than we paid for the tv and do what they wanted with it. lol
Posted on Sep 19, 2012
"My sony bravia kdf46e3000 wont always light the lamp when first turning tv on. I can see it sparks the lamp but the lamp only stays lit for about 3 seconds. The power light on the front stays green a
does the lamp fan stay on? you can see thru the back if the fan is running. If it is not running you need to replace it.
If it running you may need a new lamp driver/ballast part# 1-480-180-21 https://www.encompassparts.com/model/SONKDF46E3000/_/_/Sony/KDF46E3000/
then there is the possibility the new lamp is bad,, Sony's like Sony OEM lamps
Dec 20, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
My sony tv sxrd has a greenish tint is this worth to fix
Actually what do you want to know? Provide more details please.
Jan 29, 2013 | Sony sxrd projection tv xl 5100 lamp ks...
Sony sxrd ks-60r200a diagram
Sony or Google the model number for service manual.
Dec 03, 2012 | Sony sxrd projection tv xl 5100 lamp ks...
Sony Tv KS-60R200A..i replaced the lamp and the display still green in colour. any one know the problems? ..thank you.
A lamp will not cause display to change color---I would suspect a issue with the the optical light engine the set has.
Google your model number with "known problems" "light engines" and so on--the information is out there for free.
Jun 15, 2012 | Sony Televison & Video
Just replaced lamp/housing and now tv turns off after 2 minutes of being on. Green light flashes continually(about 30 sec.) then tv turns back on and the cycle continues. The tv is a sony bravia...
Strange situation, have you tried unplugging it for a few minutes and letting the TV cool. I have a older 2006 Sony SXRD rear projection and it takes forever to turn back on if you shut it off then turn it back on. Check this link and maybe its giving you a blinking code. Try counting the number of blinks. Hope this helps.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 17, 2011 | Sony KDF-50E3000 Television
My sony sxrd 60 comes on only for a sec than go off and red stanby lamp blinks 4 times,i have cleanned vents and checked bulb door,can only turn tv off and back on ,and still onlly get screen to show...
4 times red light blinking indicates problem with exhaust fan that is not running and tv shuts down instantly due to protection mode activation.
Please check exhaust fan and make sure its connector is plugged in and fan runs freely.
Thanks.
Apr 19, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
My SXRD 60" Sony LCD TV turns on. green light flashes about 6 times, then solid green. But just as screen starts to light up, turns off, solid green light turns red and blinks red four times, then stops. a...
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Oct 10, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Replace bulb tv wont turn on
make sure the lamp and lamp door are seated properly. does it blink any codes. 3 blinks is lamp or lamp door not seated properly
Jun 25, 2009 | Sony KDS-60A2020 60" HDTV
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Mar 16, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Televison & Video Logo
261 people viewed this question
Top Televison & Video Experts
