Question about Toshiba Computers & Internet
The screen is flickering. The only way I can use my computer is if I wedge it up against a wall. how do I remove my screen so I can fix the cable to the LCD display without breaking anything else. I have a toshiba satellite P205D-S7454 and the cable is loose to the LCD screen. Can you please send me a diagram how to take the screen apart Please. C. Schwartz
  • 917 Answers
The following link explains how to remove the keyboard. If you do this, you will be able to see the LCD cable.
http://www.batterycentury.com/toshiba-satellite-p205d-s7454-keyboard-p-79732.html
Posted on Mar 23, 2011
Blank screen will not turn off
You turned on your laptop and horrors upon horrors, the screen is BLACK! You see that the laptop has power but besides that nothing is happening. I want you to know that there is a very good chance you can get out of this situation quickly and without any cost. This fix works on all brands of laptops:
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up. Replace your battery.
or
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel.
Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on.
If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective.
If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
Dec 27, 2012 | Computers & Internet
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
Acer aspire 3610 screen flickering
It sounds like your video cable or your Lcd Inverter cables might be loose. You will need to take the lcd apart to get to them. The video cable is on the back of the LCD screen at the top. Remove it, then push it back in and use a piece of tape over where it connects to hold it in place. Also remove the other end of the video cable from it's connection and plug it back in. The lcd inverter is at the bottom under the lcd screen. It has two cables going into it. Remove both cables and then plug them back in. Put everything back together and hopefully your problem of flickering will be solved.
Mar 30, 2012 | Acer Aspire 3610 Notebook
How to solve a flickering screen for toshiba satallite m200? as i open my laptop its hang and the screen is flickering...
@crisanne_21
Most of the time, that cause of that flickering screen is a defective LCD flex cable or sometimes called LVDS cable (this is the cable that attaches the LCD panel to the motherboard - it can be caused by a loose connection or simply, it just may have worn out due to opening/closing the lid). The only way to fix that is to replace disassemble the computer and check if there's a loose connection on that LCD cable. If disconnecting / reconnecting the LCD cable doesn't fix the issue, you might need to replace it Disassmebly guides can be found here.
Good Luck
Sep 05, 2011 | Toshiba Computers & Internet
Flickering Screen on Model P105 Toshiba Satellite
on the back of the LCD is a cable that goes from there to the Motherboard. Try reseating that cable on both ends. If that doesn't fix it then it has to be a problem with either the screen or the cable behind the screen.
Aug 11, 2009 | Toshiba Satellite A105 Notebook
Wavy screen
Sounds like power interference. Try a different wall plug or power cable
Apr 16, 2009 | Computers & Internet
Picture flickers on all inputs.
If your having pixelation,try disconnecting other tvs
from the wall.you may have a noise or DB drop off or surge issues.check all splitters from the tube to the soffit of your home.If you find one upside down out side ,water maybe be getting in.Remove all snap adapaptors,screw on only.Splltters are
cheap,,easy way is spend $3 extra a month to have your cable Co repair or replace any seeping cables or adaptors and/or splitters.
Feb 05, 2009 | Toshiba 46HM95 46" HDTV
Monitor screen shaking and flickering
Check to make sure the cables are connected tightly. Wiggle the cable, does it get better or worse? Might need a new cable. And reseat the video card inside the computer. If that doesn't fix it, then yes you will probably need a new monitor.
Jan 15, 2009 | Acer AL1917W LCD Monitor
Screen flickers
yes i have had this problem before
the propper signal isnt getting to the screen from the mother board
has anything been spilt on the screen or the computer its self
i would suggest taking it to a tech they should be able to fix your problems
Jul 19, 2008 | Computers & Internet
LCD/Video Card? on IBM ThinkPad T30
hi, u will have to open the top cover, there u can see the LCD cables going to the MB, clean the connectors at both ends, i.e MB &LCD..let me know
Jan 13, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
