Question about Western Digital Scorpio Blue 250GB PATA 2.5" Mobile Parallel ATA Hard Drive
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C only shows 127GB of space and drive D only shows 100MB of space. How can I get the full 250GB on one partition, or how can I do it with two partions (C, D)?
  • 2 more comments
  • richnjenn Mar 23, 2011
    I did what you said and it shows exactly what my laptop shows, C-127GB and D-100MB. My BIOS reads it as 250GB
    it just changed back to 100MB after i pressed ok
    this will cause me to lose all my data correct?
    it just went back to 100MB
  • 158 Answers
You wont get the full 250gb. check unallocated drives under disk management. right click on computer then properties, go to disk management and check for unallocated disk, format the unallocated disk to get the whole capacity but it wont be 250gb much like 220gb or something close
Posted on Mar 23, 2011
    i tired this and there are no unallocted disks
  • Allan Dale Dela Cruz
    Allan Dale Dela Cruz Mar 23, 2011
    try to format win 7 again with just one partition C then when win7 is full installed try to check disk management again. and shrink it if you want two partitions for your drive
  • 11,800 Answers
Install a partition manager program like
http://www.partition-tool.com/personal.htm
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
  • 1 more comment
    I tried exactly what you said and the program reads the same as disk management C=127GB and D=100MB. The BIOS reads the drive as 250GB
  • Azrael SRL Mar 23, 2011
    Open the program, right click on D and select Resize then add all the remaining free space.
    No.
How do i find out which hard drive is compatible with my acer aspire 5733
Compatibility is something that is not something to worry about these days. It's either the same type of HDD or not. While some Manufacturers of the laptop itself may have a special HDD with and extra feature... like shock detection (Toshiba) it would still not be necessary to get the same one unless you found the feature useful. As long as it is either SATA or PATA. But more than likely it SATA as PATA is very old. Speed is an option as a matter of fact. 5400 RPMs is optional while you could increase speed to 7200 RPMS at a higher cost.
You can even super upgrade to Solid-state drives that are still the same as your SATA, but use spinless technology for optimal speeds! The power is yours!
Oct 24, 2013 | Acer Aspire 3002LCi Notebook
I need the right version of webcam for acer travelmate 5744
Webcam software should be available here
http://bit.ly/19RygCU
It's an application that you download and when you run it, it installs both the webcam driver, as well as the program to use it.
Good Luck!
Oct 16, 2013 | Acer Travelmate 5744 15.6 Inch Laptop...
Unlock a wd scorpio black 250gb
I would just delete any partitions and format. Hard drives are extremly hard to lock down, especaily after connecting on a differnt machine.
Insert the Window install disc and boot from to do a clean setup, instead of going through Windows.
Dec 31, 2012 | Western Digital 250GB WD Scorpio Black...
Had acer aspire 4720z 250gb HDD & 2gb RAM windows vista which crashed and hard disk damaged; have replaced it with a 320gb HDD and installed windows 7 but do not have the acer drivers ...webcam etc I...
Click here to download Windows 7 Drivers for Sound Audio, Bluetooth, Webcam Camera CardReader, CIR and Modem Driver
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 08, 2011 | Computers & Internet
I have a ACEer 5315 model no ICL50 running Windows Vista. To say Vista is **** is an understatement. I want to switch to Windows 7 but guess I will need a lot more RAM for this. Can I upgrade Ram on this...
I recommend that you switch to Windows 7 without upgrading your RAM. Windows 7 is a lot faster, better and uses less RAM than Vista. Recommended RAM for running Windows 7 is 1GB but I have installed them on a Centrino 1.5GHz with 768Mb of RAM and they run perfectly.
So make the upgrade to Windows 7 anyway and if you feel that you need more power then you can get more RAM.
Also, download Windows 7 upgrade advisor to check if your pc is compatible. Download upgrade advisor here.
Feb 06, 2010 | Acer Aspire 5315 Notebook
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
My Acer Lap-top Aspire 5570Z with 80GB HDD & 512 MB DDR2 is very very slow. Can its DDR2 be upgraded to 2 GB.
what the max ram is for this laptop? I bought 2x2GB dual channel ram for it and windows vista home premium (32bit) only recognizes upto 2GB, but CPU-Z recognizes more than that.
Mar 17, 2009 | Acer Computers & Internet
Western Digital Scorpio Blue 250GB PATA 2.5" Mobile Parallel ATA Hard Drive Logo
172 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
