Bose Companion  II Computer Speakers Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My left speaker has a flutter sound. In and out.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1772
Points
Try unplugging the power chord to the speakers for a few minutes. This solved my problem but i have to do this periodically, especially if i have left the speakers on overnite.
Brian Sullivan
Level 3:
  • Master 27,725 Answers
  • Posted on Mar 23, 2011
Brian Sullivan
Master
Level 3:
Answers
27725
Questions
Helped
5664218
Points
79191
Try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
My obh-18 is causing my speakers to violently flutter
It sounds like they are being over driven. Can I get an idea of how you have it hook up?
1helpful
Tar like adhesive has gone sticky round speaker cones and volume has droped
The tar like sticky substance is the suspension of the speaker cone and there is nothing wrong with that. Its doping compound applied by the speaker company to damp the speaker ( Was it not always there? ) If the suspension has come off the bass notes will flutter, if not its some other problem. Play some music and put your ears near the tweeters flared horn to see if they working. Nearly 30% of your sound comes from the upper part and if you have damaged it there will be a volume drop.
These speakers are quite complicated on the inside. It has two amplifiers, one for the woofer and one for the tweeter. It also has a digital sound processor. Any thing could be at fault, even a simple wrong setting.
1helpful
Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Jul 13, 2010 • Casio Music
1helpful
My speakers vibrate, like if you had a moth fluttering around inside your ear drums. I cannot stand having the speakers left on when there is no sound. I have tried adjusting the cables, lowering the bass...
Speakers have a kind of cardboard like membrane that the wires attach too and a magnet that are used to create sound. The cardboard like membrane can become worn, brittle or might be defective when you got them but if it breaks loose from the magnet or the surrounding frame that it is attached to it can vibrate very easily and create unwanted sounds. There is really no way to repair this that I know of. To make sure you might try the speakers with some other kind of system or computer but I think they're probably broken and might need to be replaced.
Flutterin sound in tv
try turning the bass down and see if this helps the fluttering. If it does help a little most likely it is a blown speaker. Can replace at radioshack for under 20 dollars. It is hard for me to tell since i am not there to diagnose but also can you do a balace to go completely to the right with bass up and see how it sounds. now with bass up turn the balance to go to left speakers. if you hear fluttering from one side that means a speaker or speakers from the side that is fluttering need to be replaced. i hope this helps and good luck fixing this.
No sound on left side.
RE-check the audio amp on its own see if this happens with any input device...
Re-check the connections, and be sure your cable wires are all in good condition....and that you have the proper input/output ports correct.
Yamaha RX-V861 Low frequency "flutter" after turning on
How close to your video monitor is this rxr? It is not shielded well as far as sync circuits in your TV are concerned. Refer to manual...accordianman
5answers
Low level noise causing sub flutter
the ground may not be coming from your stereo it should be coming from a loose wire under the hood. Do u have the factory radio? that might be it if u do
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
