Question about Microsoft Kinect Sensor for XBOX 360
The kinnect sensor does not seem to work. it is pointing downwards and does not move. And the picture on the screen (small picture in picture in little box on the lower right side of the tv screen) is black with some white static lines. It was working a few days ago and we have not dropped it or anything. What is wrong and what can we do????
    Problem Solver:
  • 5 Answers
If it is pointing down you can adjust it or do what is in best solution
Posted on Jul 25, 2011
  • 158 Answers
Try to recalibrate the kinect sensor, go to settings on dashboard then kinect. re-calibrate
Posted on Mar 23, 2011
Desktop picture is too large which means that when pointing the mouse downwards the top line of the desk top will dissapear.
I think what you have done is accidently magnified your screen slightly. To correct this hold down your ctrl key and move your finger on the mousescroll button back. Hope this helps.
Jan 31, 2011 | Apple 24" iMac Desktop
Not sure which philips i have, but suddenly lines have appeared at the top of the picture, going the width of the screen, about 4 inches down the screen, and moving downward.
It seems you may have a vertical linearity problem. Check all electrolytic capacitors around the frame output stage. The frame output ic may be at fault but this is less likely.
Regards Vintie
Aug 22, 2010 | Philips Televison & Video
Displaying obstruction when trying to turn on printer.
Hi there
Ok you can try this.
Error code: 1200
This error code is commonly associated with the Dell 922 printer. Usually you might see the cartridge moving front and back and slamming itself against the printer. You need to tighten the strings located on the back of the printer and then it should work fine
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartridges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat.
Lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 17, 2010 | Dell 922 All-In-One InkJet Printer
Our xbox 360 video has a black screen with small white dots moving downward. Rebooting doesn't work. We still get audio.
this is a gpu issue, you need to contact microsoft support, the xbox 360 has a lot of problems as it is a flawed design.
Aug 04, 2009 | Microsoft Xbox 360 Console
The Same problem
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
Jun 05, 2009 | Kodak EasyShare M1033 Digital Camera
I have a kodak m1033 turns on then shuts right off
May 18, 2009 | Kodak EasyShare M1033 Digital Camera
Hot Air
I am assuming it's turned on, and plugged into electricity, but at that point I have no idea what you are doing to try to cool the air, as in, what settings do you have it on?
Does the front indicator panel, led lights, have any signals indicated?
Are you exhausting air out of the room, and using both exhausts?
Are the exhaust lines straight? Pointed upward or downward? Sideways kinked?
Are there Hard S's in the exhaust lines that would cause backup of air flow?
Has a family of small penguins (very small) moved into the exhaust hoses, thereby blocking flow?
What is the actual temperature before use, and during use after a given amount of time and at what is the outside ambient temperature?
Did You lay it down or sideways before turning it on, or has it always been in the upright position?
Is the filter clean?
Have you cleared out the drainage hoses? They may be backed up.
Are your vents open?
Air in, air out.
try leveling or having the exhaust hoses point down and not up to exhaust.
Aug 01, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Pictures nearly black (overexposed )
Hi! It's weird that 1/2 of your photos were too dark. You didn't mention about the flash. Eventhough it is on auto mode, at night you still need to turn on the flash manually. Normally, it is a curve arrow pointing downward, you need to point your mode selector there. What brand of camera are you using though?
May 05, 2008 | Canon PowerShot A540 Digital Camera
How to put toner in the printer
Open the front cover .You will see a green leaver pointing downwards , lif te leaver to the upwards position on the left side underneath the toner you wil see a little green pin ,push it downwards to release the toner pull towards you , move the old bottel little bit backwards and lift , it will come out , remove the black turn off screw from the new toner and insert it with the end were you unscrewed the cap pointing towards you.push back the holder until it clicks , move the green handle downwards again and close the cover .
Nov 11, 2007 | Gestetner DSm735sp Printer
Problems with Image on Polaroid DVD player
try moving thew screen to its down potsion because the switch that reverses the picture is not working. theres a small switch inside the piviot point inside so that when you move down the screen all the wat flat away from the player the screen is supose to reverse so it can be veiwed. Good Luck
May 23, 2006 | Polaroid PDM-0723 Portable DVD Player
Microsoft Kinect Sensor for XBOX 360 Logo
702 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
