Question about LG Heating & Cooling
Model: LSJ092V-3 Cooling selected When a/c switched on with the remote the set temp shows on readout on wall unit and temp LED's either side of set temp flash on and off for a couple of seconds and then go off leaving the set temp reading only,the compressor does not start. The fan in the wall unit runs.
  • barklay Mar 23, 2011
    Thanks Dioteic
    The room temp is 26C and a/c set 21C,and compressor and outdoor fan do not start.
    Normally when unit is calling for cool, LED,s on display adjacent to temp display are on,now they are off.
    It seems temp signal is not being computed and sent to start compressor.
    Regards
    Barry
    Genius:
  • 1,622 Answers
Hi, you will need to troubleshoot the air condition...
follow the tips below:
On a hot day, there are few things more frustrating than a faulty air conditioner. If you own an LG air conditioner, you may occasionally experience issues that prevent the unit from effectively cooling your home. Some problems occur more commonly than others, so it is a good idea to familiarize yourself with these issues to make troubleshooting easier.
Fan Motor Does Not Run
In some instances, you may notice that your LG air conditioner's fan motor is not running. The fan motor's failure to run may be due to a simple power issue. Check to make sure the unit is plugged into a working outlet. If the outlet has the proper voltage, but the fan motor still does not run, examine the air conditioner's power supply cord. A damaged cord should immediately be replaced. When there is no damage to the power supply cord but the motor still does not run, there may be an issue with the air conditioner's installation wiring. Consult the wiring diagram in the installation or owner's manual to verify that all wires and switches have been connected properly. Tighten any loose terminals as well. If the air conditioner's fan motor does not rotate, the fan blade may be coming into contact with the shroud or the cross-flow fan may be striking the scroll. Adjust the assembly so all the parts are properly aligned.
Compressor Does Not Run
In some cases, an LG air conditioner's fan motor may function properly but the compressor is unable to run. As with a stalled fan motor, check the unit's voltage requirements to ensure it is receiving an adequate power supply. Consult the unit's wiring diagram and examine the air conditioner for loose or misplaced wires. Tighten or repair any loose connections and terminals. If the wiring is in order, make sure the thermostat is set at the coldest setting and restart the unit. The compressor may fail to run if there is an issue with the capacitor, so make sure that it falls within the manufacturer's acceptable rating and that it is not shorted or damaged. Replace if necessary. In addition, a compressor that fails to run may be damaged itself. If it has an open circuit, replace the compressor.
Noises From the Fan Motor
An LG air conditioner's fan motor may sometimes make excessive noise. Check to see if the unit's grommets are worn or missing and replace them if necessary. The fan motor may also make excessive noise if the fan itself is out of balance or cracked. Replacing the fan should reduce the noise.
Dirty Air Filter
Periodically, an LG air conditioner's air filter may become dirty. If the air filter is clogged with trapped particles, the airflow from the unit may be blocked and the cooling capacity is reduced. Check the air conditioner's filter twice a month to determine if cleaning is required. Pull the air filter out of the front grille assembly and examine it for buildup. If dirty, clean the filter with lukewarm water. Be sure to shake the air filter afterward to get rid of any excess water and replace it in the grille assembly. When an air filter becomes torn or damaged, it should be replaced with a new filter, which can be purchased from an authorized dealer or customer service center.
Hope it helped..
Posted on Mar 23, 2011
  • SANYADE  OMOTOLA
    SANYADE OMOTOLA Mar 23, 2011
Blue Star 1.5 ton 5 star inverter split AC remote "TEMP" button seems not functioning. does any one help me? how to check this function as always remote is showing set temperature.
does that on mine as well
the temp is what is on the inside wall unit when turned on the remote reads 25 and the inside unit reads 30 but eventually comes down to 25
Apr 14, 2017 | Star Heating & Cooling
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
I have a 12yo Sharp r-430cs microwave. The LED is not displaying all the "lights" in the numbers/alpha readouts. It is missing a lot more of the readout than it is showing. Everything else is working
Go to Sharp's website and check availability of the clock/timer readout board. Being that old you may not be successful, but it;s worth a try.
Oct 21, 2014 | Sharp Microwave Ovens
We have a carriers air con that is about 4 yrs old it has a remote control and digital readings on the unit it is in the wall we can not get it to heat but it does cool we didnt put this in it was here...
Normally all air-cons carry an identifying label on the compressor unit. It has to by law state the gas used. On a split system this would normally be on the outside unit. Sometimes an additional label will be on one of the ends of the inside unit. Some units only do cooling - you need to check once you've found information. Check your remote control 'Mode' setting is correct - it should show a small 'sun' to indicate heating. A small 'icicle' looks similar, but means cooling. Then check temp setting is high enough to cause heating.
Jun 12, 2011 | Carrier Heating & Cooling
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
My air condition unit stop runing and a small green LED just abov
You can call lg and they can tell you the fault code they are also listed on the back of the control panels where the wiring is in the outdoor unit on most units cut the power off before going into these panels
Sep 14, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Remote will not open garage door but the door still works
CHECK TO SEE IF THE LED ON THE WALL CONTROL IS FLASHING.
IF IT IS THE LOCK / VACATION SWITCH HAS BEEN ACTIVATED. THIS IS USSUALLY A SMALLER BUTTON ON THE WALL CONTROL OR A SMALL SWITCH ON THE WALL CONTROL.
WHEN THIS HAS BEEN SET TO UNLOCK THE UNIT, ALL OF YOUR REMOTE FUNTIONS SHOULD WORK.
Nov 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Soleus MA-9000AH blows hot air
Sounds like the compressor is not running. This model had lots of problems with over heating. It also will never really blow more than a moderate cooling through it. Since you have cleaned all the filters and is still 100 deg, I believe the failure will be the compressor itself or the capacitor.
If you find an oily residue in the drain or on the pipes, it may have simply leaked the refrigerant out. Good Luck!
Jun 18, 2008 | Soleus MA-9000AH Air Conditioner
I have a frigidaire sisde by side refrigerator model # FSC23F7TDW. My Temperature control is reading the the freezer & fresh food temp in centigrade. How do I get the Temp display to read in...
Same Guest as above posting this ... By the way, I have a FLSC238DS5 ... I spent 45 minutes on phone w/Frigidaire this afternoon (Phone#: 706-860-4110 Option 1 --> then Option 3). Didn't get anywhere. They say there are 3 solutions that should change it from C to F: 1) In between LED readouts for "Freezer Temp" and "Fresh Food Temp" there is a mode button that is hidden under the plate that you can press w/your finger OR 2) Hold "Fresh Food Temp" Up Arrow Key down, within 5 Seconds press "Freezer Temp" Up Arrow Key 3 times and it should change C to F or vice verse. Didn't work for me so she said 3rd option was to have a service tech come and diagnose. She said there would be a charge. I am not paying to have somebody come here to resolve this issue. That is when I asked her to escalate it to a supervisor which she did. Hopefully, I get a call back & a solution. Stay tuned ...
May 24, 2008 | Refrigerators
Heating & Cooling Logo
56 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
