Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
How do i cutoff power from hot water heater - Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
  • 604 Answers
Typically the power to your water heater would be fed by a circuit breaker in the power panel in your house. water heaters (electric) consume a lot of power and therefor need their own circuit. If your circut box isn't labeled what you need to do is first turn the water heater up so that you can tell that it runing, you can't see this but if you listen closely you should be able to hear it, get someone to help you with this and cut off the power (trip breaker) till you find the one that stops the sound. If you have a volt meter you could take the cover off the power box (where you water heater is hooked in) and put the meter across the black and whiter wire so you see a reading of 110-130 volts. again have someone help you and cut the breakers one by one till the meter drops to 0 volts (or very close to it) when it does, make sure to label the breaker so you know next time.
Posted on Mar 23, 2011
Dodge magnum pickup heater wont get hot
test the parts and fix it. God bless you
Test and replace a heating element:
  1. Turn off power at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Test and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electric service panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Oct 28, 2013 | Water Heaters
Since installing Rinnai RC80i tankless water heater, the performance of the dishwasher has diminished. The dishes aren't getting clean. I suspect the water temperature is not hot enough. The thermostat is...
follow this steps and fix it. God bless you
Drain a tank:
  1. Shut off power at the electrical service panel and post a sign warning others not to turn it on.
  2. Close the cold-water supply valve and open a hot-water faucet somewhere in the house (to speed draining).
  3. Attach a garden hose to the drain valve and run it outside the house.
  4. Open the drain valve and allow all water to drain out.
  5. To refill the tank, close the drain valve tightly and open the cold-water supply valve. Also open a nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full and the faucet can be closed.
  6. Once the tank is full, turn the electrical power back on
  1. Turn off power at the electrical service panel and post a sign warning others not to turn it on.
  1. Disconnect power to the heater at the electrical service panel and post a sign warning others not to turn it on.
Oct 20, 2013 | Rinnai MCC-91-2W Commercial Remote...
Crown boiler
follow this chart troubleshooting and fix it. God bless you
  1. Disconnect power to the heater at the electrical panel and post a sign warning others not to turn it on.
Drain a tank:
  1. Shut off power at the electrical panel and post a sign warning others not to turn it on.
  6. Once the tank is full, turn the electrical power back on.
Test and replace a relief valve:
  1. Lift the spring lever on the valve to fill a small cup. Check the cup for sediment.
  2. If no water spurts out, or if water continues to drip after the valve is released, replace the valve.
  3. Cut power at the electrical panel and post a sign warning others not to turn it on. Close the cold-water supply valve.
  4. Drain a few gallons of water from the tank.
  5. Unscrew and remove the discharge pipe if used.
  6. Loosen the relief valve with a pipe wrench, then remove the valve by hand.
  7. Apply pipe tape to the threads of the replacement valve and screw it into the tank by hand. Tighten it with a pipe wrench. Screw the discharge pipe (if any) into the valve outlet.
  8. Refill the water heater and restore electrical power.
Replace a drain valve:
  2. Close the cold-water supply valve and drain the water heater completely (see above).
  3. Unscrew the drain valve with a pipe wrench.
  4. Replace the drain valve with an identical unit wrapping the end with pipe tape.
  5. Refill the tank and restore electricity.
Oct 14, 2013 | Water Heaters
No hot water volume at shower until power is turned off and on to unit
oubleshoot a thermostat:
  1. Shut off power to the heater at the electric panel and post a sign warning others not to turn it on.
  2. Unscrew and remove the electric water heater access panel.
  3. Using a small screwdriver, turn the thermostat dial counterclockwise to lower the temperature, or clockwise to raise it. If the water heater doesn't maintain the proper temperature, test the thermostat.
  4. Disconnect one wire to the upper thermostat to test it. Set a multimeter to RX1 (resistance times 1) and touch a probe to the thermostat terminals as indicated in the owner's manual. Depending on the model and the terminals tested, the tester should show infinity ( open) or about 0 ( closed).
  5. Test the lower thermostat in the same manner.
  6. If necessary, replace the thermostat. Unscrew it from its mounting and install one of the same model, size, and rating. Once you install it, adjust the thermostat following instructions in your owner's manual.
  1. Turn off power at the electric panel and post a sign warning others not to turn it on.
  1. Disconnect power to the heater at the electric panel and post a sign warning others not to turn it on.
Oct 08, 2013 | Noritz 6.3 Gallon Residential Tankless...
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
Glowworm economy plus
follow this test and fix it. God bless you
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electric service panel 3eaa58c5-8512-433f-991a-4ed5eb1cf944.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 01, 2013 | Water Heaters
My Rheem hot water heater is leaking, and I need to shut the water off, how and where do I do that? Model # 71/40D
Assuming this water heater is tank type..... Most plumbers will have a cutoff valve located at the water heater or they should have.... if there is not a valve there then the next option will be at water meter located outside or in basement depending on the area you live in......if you dwelling is supplied by a well then you may have a valve in next to the pump or determine what breaker supplies the power to well and turn it off.... ( this will take a little time for the pressure to drop low enough to actually slow the water leak) if the leak is on the tank then you must cut power off to the unit and remove unit or drain the tank to stop the water from spreading( if unit is an electric)
Apr 17, 2012 | Rheem Water Heaters
Check the relief valve,drain and element's,water lines to make sure that they are not the source of the leak. If the tank is leaking you may be able to fix it for now.
The tank depending on condition of the tank if it is pretty sound. Clean up the area of the hole with sand paper. Go to any hardware store and get a JB Weld two part kit. JB Weld will fix almost anything . You can go to www.jbweldit.com for more information about this product. I wish you well and hope this will fix it for you.
Jun 26, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My Rv water heater will not stay lit for longer than 2 minutes. There is no sticker with the product name on it. The model # is G6A-4E, it uses a GAS LIGHTER direct spark ignitor to lite. I have cleaned...
If your water heater dies, here's a quick way to find out if it is the Thermal Cutoff. First, MAKE SURE there are no obstructions in the flue tube. Then turn off the water heater's electric mode and turn on the gas mode. With the exterior access door open and looking at center of the water tank you'll see a black foam-covered area with 4 wires running to it. Look for the area marked T-STAT with two brown wires running to it. One of the wires will have a piece of clear tubing over it that covers a large diode- this diode is the Thermal Cutoff. (Mine didn't look burned or in any way defective, so a visual inspection won't tell you if it's bad or not.)
Remove the diode from the T-STAT terminal lug then disconnect the other end of the diode from the brown wire connector. Now connect the brown wire (without the diode attached) directly to the T-STAT terminal lug. Give it a few seconds and the water heater should turn on in gas operation mode. If it does, that means the Thermal Cutoff is bad and you'll need to get a new one from Atwood. Leave the wire hooked up, turn on the electrical mode to supplement gas mode (if you want) and you'll have hot water till you get the new Thermal Cutoff.
If the water heater doesn't turn on after a minute or so chances are it's not the Thermal Cutoff and you'll have to look elsewhere for your problem.
May 03, 2010 | RTO Suburban Rv Water Heater Dsi Gas Valve...
No hot water in our tankless water heater
You may find this info helpful.
http://www.stiebel-eltron-usa.com/pdf/install_tempra.pdf
If you don't find what you need, you will need to contact them directly.
Apr 05, 2009 | Stiebel Eltron TEMPRA 12 Tankless Water...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
35 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
