Question about Whirlpool Refrigerators
Lights will not come on inside on reg side when door is open
    Sergeant:
  • 194 Answers
LIGHT MAY BE FUSE
OR
THE SWITCH MAY BE FAULTY
Posted on Mar 23, 2011
Passenger door can be opened from inside but not from outside...how too fix???
Remove the door lining and look inside by the lock. There is a linkage that has come adrift. To remove the door lining, remove handles, escutcheons, and arm rests. Using a wide blade screw driver gently pop the plastic rivets that hold the lining to the door.
Dec 02, 2015 | Cars & Trucks
Brake light problem/side lights
Check on the brake pedal switch, sometimes its bad.
Source: All About Car cartechhome com
Dec 01, 2017 | Cars & Trucks
Audi tt x reg - the key fob is not working. Additionally, the hazard warning lights intermittently come on when i the engine. The hazard warning lights do not stop flashing and i often have to try...
this can be a big problem so will start on easiest first. and try to repair as going, the passenger door the problem with this could be the solenoid for the door lock. and or the switches in the lock. driver door has the same but is the master door. ie if you open door from unlocking at pass door it will only open this door, drivers side will open all doors. flashing hazards this could be because the alarm is not completely turned off this could be because of the doors, mainly the drivers side. try to find the fault with the door lock and get back to me when you have found the fault. you will need a meter to check for volts and the switches, check them as lock unlock from the inside and the key to make sure they working. dpd spray should be able to clean them if you can spray into the lock and housing that is plastic. give a good flush out after its working wipe up the mess from the spray and mear grease on the lock moving parts.
Jun 26, 2017 | 2000 Audi TT
Pt cruiser tail lights front light & driverds door wont open
The headlight, brake and turn signal all run out of the turn signal switch. this is what causing you to loose those items. the door is a clip that has broken inside the door that goes to the handle, you will have to take the door panel off to find the rod that is hanging
Jun 14, 2010 | 2006 Chrysler PT Cruiser
The interior lights will not come on when you open either front door but work fine on the rear doors.
check the pin switches where the front doors meet the B-pillar they get stuck from getting slightly bent from regular use or getting gunk in them look at the one on the drivers door first you may need to remove the plastic cover on the inside of the B-pillar to get to the wiring unplug it and shut the door then open the passenger door and see if the lights come on if they do then the driver side switch is bad if not do the same thing on the passenger side.If the lights start working then the one on the passenger side is bad.
good luck.
Jan 02, 2010 | 1999 GMC Suburban
N REG VAUXHALL CORSA CENTRAL LOCKING NOT WORKING
central locking on my 93 corsa with standard key, not electronic type as used on later models, all doors are locked and refuse to open, ive checked fuse and thats ok, doors refuse to open from inside the vehicle and from outside, only the tailgate will open from the key, any ideas ,,, thanks dave
Apr 17, 2009 | Ford F Cars & Trucks
Park lights and dashborad lights went out whats wrong?
your fuse panel is on the left side of the dash. open the driver side door and look at the side of the dash you will see a panel door thats marked fuse panel. you can't miss it.
Mar 13, 2009 | 1998 Plymouth Breeze
Keeps making beping sounds
Not shuting off..it is off if the dispaly and lights are not illuminated
Dec 23, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
