Question about Toshiba Office Equipment & Supplies
I have a problem in the Toshiba copier toner consolidate heater and repeat words in the paper
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Check the quality of toner,clean the heat roller,reduce he temperature in 08-410 to 3 default value is 6 in Toshiba e-studio 16,160,163,166,181,205.232,
perform 05-200 auto toner density count.
Hope will solve
Posted on Mar 27, 2011
How do I fix Toshiba E-studio 355. When I do the printing the toner dose not hold/stack on the paper, It can be wipe with your Hand. Is it the problem with the fusser?
In general on all machines, after the image is laid down, the toner on paper is run through a heated roller assembly called the fuser. This is normally a heater inside a hollow aluminum roller. As the paper exits the machine it should be warm to the touch. It is most likely your heater is bad.
Jul 19, 2016 | Toshiba OEM ESTUDIO355SE 35 PPM...
The & symbol is on the screen - does this mean the copier needs toner?
i am having toshiba 1370 printing is not clear words are repeatin in paper tell solution
Jan 30, 2013 | Toshiba 1370 Black and White Copier
My Toshiba 1360 is jamming every other sheet at the exit from the heated roller. It seems that the paper is curving down slightly and catching on the ribs before the paper exit sensor switch. The switch...
At the exit of the printer, there is the fuser unit (heating roller, which heats the paper to fuse the toner on to the paper. The fuser (heater) is covered with the Teflon sheet Sleeve. So that the paper is never directly in contact with the heater and heat is transferred through Teflon sleeve.
I have noticed Paper Jam at the outer paper bin in case of damaged Teflon sleeve. A very clear indication of broken Teflon is that there is a loud cracking noise, when the printer initializes (printer power on) or while printing a page. Secondly, the toner fails to fuse properly to the paper and gets erased when rubbed. You may use a torch to inspect it as well. Secondly, inspect the paper path for any obstructions. There may be a torn piece of paper. Inspect the gears and roller from the input tray to the paper exit point and look for any stuck roller.
So, it is recommended that make sure that the Teflon Sleeve is OK and there is no obstruction in the paper exit path.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 14, 2011 | Toshiba 1360 Black and White Copier
When i use Hp Laserjet P1007 to print, on my page occur repeat the words of overlap and Blur with ink on paper. please help me solve this problem ->contact me at email address:levinh2585@yahoo.com...
You either have a bad toner cartridge or have a problem with the fusing assembly. If it's the fuser will need to have the fuser replaced.
Here's how to tell which it is. Measure the distance from the original image to the first time it repeats on the page.
30.8mm (1.21") = toner cartridge
76.3mm (3.0") = toner cartridge
41.0mm (1.61") = fuser
56.5mm (2.22") = fuser
Hope that helps you. :)
Nov 15, 2009 | HP LASERJET P1005 Printer
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Printing paper with to much toner ink on the paper. Words are unreadable.
If this is a cartridge refiling case,
I think its an over refill
try with refill again (complete empty (also waste) is necessary for best result)
May 21, 2009 | Brother Office Equipment & Supplies
Toshiba estudio 210c
toner missing on that side of developper ( where toner is stored to go on paper) or drum
Sep 01, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
61 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
