Question about Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer
Duet steam dryer soaked clothes and had alot of water setting in drumclothes were dry and wrinkled when i put them in the dryer 5 minutes later they were soaked.
Turn off the water or disconnect the water hose to your dryer.
Call your serviceman and tell him to order a new water solonoid for your dryer.
You can dry without the water hooked up to the dryer.
The steam cycles, however, will not have steam due to the absence of water.
Posted on Apr 01, 2011
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
Whirlpool Duet Steam is not heating to dry any clothes
Don't have your model so I couldn't bring up the schematic some will run with an open thermal fuse I suspect thermal fuse which is non resettable I've only run across a bad thermistor once based on the age check the exhaust exiting the house and at the dryer this a safety fuse designed to open due to excessive heat if the dryer cannot breath restricted exhaust.
Jan 21, 2014 | Washing Machines
Duet steam dryer soaking my clothes
You will need to replace the "water valve" on the unit. The solenoid is letting to much water thru. Here is a link to the part to order.
Nov 04, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
Dryer leaves mark on clothes
Clean dryer soak a towel in water and bleach , put towel in dryer and dry it it will claen the inside of dryer worked when we had pen marks in ours made the clothes blue has to do it twice
Mar 22, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
My LG dryer shuts itself off during the normal cycle and a dotted
OK, here's what it sounds like to me: The line going around the display should only be seen if you selected "Wrinkel Care" function for that cycle (and with the freshen up cycle, I beleive). With that option in use, after the dryer shuts off, if you do not open the door or turn off power to the dryer the dryer will display the moving rectangular segments and every 6 minutes the dryer will turn itself on and tumble for 10 seconds with no heat (to keep clothes fluffed up and prevent wrinkles from setting in) and will continue this cycle for up to three hours. The "Freshen Up" is the steam cycle used to remove wrinkles from 1 to 5 garments, like things that were all wrinkled up in your suitcase. Try drying with a normal or permanent press cycle, or a timed cycle. If you have additional questions or concerns, let me know.
Dec 06, 2008 | LG WM2077CW Laundry XL Front Load...
Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer Logo
670 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
