Question about Panasonic Lands Phones
Re Kx tg6461AL answering machine cant access answering machine "Greeting " to record outgoing message . have actioned steps as follows middle soft key, scroll to " answering machine " , Ok , "call screening" appears , arrow down once , dotted line appears in display in display , arrow down again , "call screening " appears . key pad number do not function when either "answering machine" or "call screening" is displayed
Beni S-P
  • 1006 Answers
SOURCE: bellsouth 2025 answering system-how to record greeting
Try those manuals here :
And please if it will help you rate it as SLOVED
Posted on Oct 18, 2007
  • 136 Answers
SOURCE: Answering Machine Message
enter answ.mach setup menu
then record greeting submenu
press start soft key
youll hear start recording mess
you have 30 sec v countdown to do message then it automatically uploads
Posted on Mar 30, 2008
SOURCE: bang and olufsen BEOTALK 1200
Make sure answer machine function is turned on. Bottom right button.
Make sure an outgoing message is set. Should see a <-> arrow in the display screen. If not, press the <-> button. To record outgoing message... the press the middle button; record out going message; press middle button. Wait a few seconds and you should be set. Hope this helps
Posted on May 03, 2008
SOURCE: outgoing greeting
Press and hold down the "greeting A" button. You will be instructed as to when to start your message. When you are done recording, release the button. To hear your recorded greeting, press the "greeting A" button again.
Posted on Jul 21, 2008
SOURCE: how to skip answering machine's outgoing message
When calling someone, press the # key to skip the outgoing message.
Posted on Aug 19, 2008
How can I record outgoing message?
Recording your greeting
1 {MENU} i {#}{3}{0}{2}
2 {V}/{^}: "Yes" i {SELECT}
3 After a beep sounds, hold the
handset about 20 cm (8 inches)
away and speak clearly into the
microphone (2 minutes max.).
4 Press {STOP} to stop recording.
5 [off]
Feb 14, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
Hi,How do I change the answer machine message?
The KX-TGA711 handset can be added to the KX-TGA7160 or KX-TGA7180 system. First, make sure that the answer system is ON. (Use the button on the base or the first few steps below.) For those base units, press the Menu/OK button on the handset. Use the Up/Down arrows to navigate to Answer System. Press the right arrow to enter the sub-menu. If the system is off, turn it on. (Answer On/Answer Off will be displayed on one line. Press the right arrow to access the item.) To record a new greeting, navigate to the line 'Record Greeting' and press the right arrow. Hold the handset about 20 cm away and speak clearly into the microphone. Press Menu/OK to stop recording. Press the Hangup/End to exit and save. A faster access route would be to press 7 and then 6 after accessing the answer system menu. The directions are on page 25 of the manual, which is available from Panasonic and here: . You can do this as a remote operation if you have enabled the feature. Press 7 to record and 9 to stop recording.
I hope this helps.
Dec 14, 2015 | Panasonic KX TGA711 1Line Cordless...
I would like to change the answering machine message
Record a Personal Greeting
Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
Press 8 (RecNewGreeting).
Wait for the system to say "Record greeting," then begin speaking.
When you're finished, press 8 to stop recording. The system plays back your new greeting.
To keep this greeting, press End. To re-record it, go back to step 2.
Aug 21, 2013 | Panasonic KX-TGA101S Cordless Handset
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
I can't remember how to record my outgoing message ?
here you go...
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
3 {V}/{^}: “Record greetingi
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Feb 01, 2009 | Panasonic (KX-TG1032S) Phone
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
Using a pre-recorded greeting
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Nov 21, 2008 | Panasonic KX-TG9331T Cordless Phone
Greeting message
To Record Outgoing Message on Radio Shack’s Answering Machine [Model 43-3829]:
Press and Hold the ANNC/DAY/<< button. You’ll hear a beep; continue to hold down the ANNC/DAY/<< button and record your message. When recording of your [outgoing] message is complete, release the ANNC/DAY/<< button. Your message will automatically play back for you.
Please let me know if you have additional questions. Thanks!
Take care,
Gail :-)
Sep 17, 2008 | Radio Shack (43-3829) Digital Answering...
Outgoing greeting
Jul 15, 2008 | GE 29869GE2 Digital Answering Machine
Lands Phones Logo
104 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
