Question about Avocent CYCLADES 32PORT ACS 6000 SAC W/MODEM (ACS6032MSAC001) Server
Hi i am unable to ping avocent from a different subnet. The firewall is in default state.
Unable to connect windows xp and windows 7 using crossover cable.
Your laptop ip address setting is correct now there is reason not able to ping windows xp and windows 7 have firewall you need to enable file sharing form windows firewall. Go to control penal > windows firewall > advanced settings > inbound rules and enable file and printer sharing.
Jun 15, 2012 | HEWLETT-PACKARD HP 630/P6200 Notebook
Will not connect to cable after powered on. Once power on it turns on and connects briefly but then looses connection to lan?
reset to factory default, flash firmware and test again.
Also take a Cross over CAT5 and a laptop, the laptop should (of cause) be on the same subnet for this test.
Then try to ping it... (command line of your laptop) ping IP-Address -t
see if the ping drops, should it drop the nic has issues and an RMA should be needed.
Thanks
Nov 24, 2010 | Avocent DSR1021 (DSR1021AM) 8-port KVM...
LAN Network, both PC's with static IP's and defaullt and DNS addresses are 192.1683.1.1 tried the other defaults. Both machines connected. when i ping each others IP's request timed out. please help
Can not really understand what exactly you have done. Please try the following steps:
1. Assign static IP on pc 1 as 192.168.1.2 assign subnet mask as 255.255.255.0. 2. No need to assign default gateway and DNS. 3. Assign static IP on pc 2 as 192.168.1.3 assign subnet mask as 255.255.255.0. 4. No need to assign default gateway and DNS.
Open dos and try to ping. In case if the ping fails then disable all the firewall on both the pc's and try again.
If you are running windows vista then in network and sharing center make sure network discovery and file sharing is enabled.
Regards,
Rashish
Aug 06, 2010 | Accton CheetaHub Classic 2040 Networking...
I have a D-link wireless router model dir-615. I jhave two pc's comming up on it, the first one up gets ip address 192.168.0.100 the second 192.168.0.101. Both have 32 bit subnet mask. The first one can...
If you have any Firewall installed in the PC which has the IP address of 192.168.0.101 disable it,Because Firewall will block the 32 bit DATA ping within the internal Network commonly with the router because Router also has an inbuild Firewall in it.
Mar 30, 2010 | D-Link (DI-711) Router
I have a class b network setup 255.255.0.0 my ip address is 192.168.5.101 subnet 255.255.0.0 i have two computers 192.168.99.100 and 192.168.99.200 that i cannot ping. but i can ping 192.168.99.144 all...
Could be they have their windows firewall turned on or they have a 3rd party firewall. Also could be they have a different version of windows running, i experienced this problem with a mixture of winxppro and winxphome on the same network.
Mar 25, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
Routing configuration
Contact an ISP for an IP address.
configure the computers in the 2 networks to have the IP address you got from your ISP as the default gateway..
Cheers
Jan 09, 2008 | D-Link DI 514 Wireless Router (DI-514)
Can't connect
it might probably a security issue , can u remember from which machine and from what ip you access the firewall before ??
Try to assign the ip from which you have last accessed your firewall
Good luck
Nov 20, 2007 | SonicWALL PRO 100 Firewall
ActionTech Wireless Gateway can't route Wireless to LAN
Disable firewall on all devices. All types of security sofwares should also be disabled in order to ping each devices.
Oct 07, 2007 | Actiontec GT704WG Wireless Router...
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? 192.168.0.227 IP Subnet Mask ? 255.255.255.0 Gateway ? 0.0.0.0 Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227. You can now try configuring the router through its web interface (192.168.0.227). This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
Avocent CYCLADES 32PORT ACS 6000 SAC W/MODEM (ACS6032MSAC001) Server Logo
95 people viewed this question
Top Avocent Computers & Internet Experts
gary433
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
