Question about Electrolux Washing Machines
My Electrolux EDE418M Dryer turns but does not heat up. Please help>
5 Suggested Answers
  • 3 Answers
SOURCE: Electrolux Kelvinator - Unit on defrost
Check the defrosting sensor on the coil or the solanoid on the reversing valve.
Posted on Jun 07, 2010
  • 32 Answers
SOURCE: so my maytag neptune electric dryer mde9700ayw
Check the vent hose going outside and make sure it is not stopped up with lint.
If this isnt the problem tour heating elements are probably bad.
Posted on Mar 03, 2011
lovejoy91
  • 691 Answers
SOURCE: Please help>>>I just bought it...When
Any set just bought or within the 1 year warranty, I would not work on because it voids the warranty call the company and try to take back and get new one.
Posted on Mar 09, 2011
Jahn27
  • 1554 Answers
SOURCE: My Dryer is turning on
The problem is a broken drive belt or it has slipped off the idler pulley. Disconnect power then remove the rear access panel and reinstall the drive belt over the motor and idler pulleys. If the drive belt cannot be reinstalled from the rear access panel or if it has been broken and needs to be replaced, you have to tear down the dryer from the top to the front panel.
Remove the screws attaching the to panel to the rear of the dryer then slide the panel rearward and off. Remove the screws holding the control panel to the inside of the dryer cabinet then lift up and roll it forward. Remove the screws securing the top of the front panel to the cabinet then lean the panel forward and disconnect the door switch wire harness. Lift up on the panel and set it aside.
Remove the front bulkhead then take the drum out through the front. Install the drive belt around the drum then over the motor and idler pulleys. Put the dryer back together in reverse order of the tear down process.
Posted on Jul 14, 2011
I have Electrolux dryer model number EIED55HIWO and it says E64code...what do I need to do?
It indicates that there is an open it the heating circuit. It most likely means the heating element has gone out in it.
Feb 12, 2018 | Electrolux Dryers
Electrolux model FEQ332CES0 spins but there is no heat. Any suggestions on why and how to repair the problem myself, thanks.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 08, 2015 | Electrolux Dryers
HOW DO I CHANGE HEATING ELEMENT ON MY ELECTROLUX DRYER?
You might try this step by step process. It is not for Electrolux, but the process should be similar. Changing the Heating Element
Apr 08, 2013 | Electrolux EIED55HMB Electric Front Load...
Wiring honeywell th8320u1008
Be sure you are looking at the letters set up for heat pump. Orange should be "O". Remove jumper between w2 and e. Then be sure you have the settings correct in the tstat for a heat pump with back up heat. Good Luck!!
Mar 28, 2017 | Heating & Cooling
Electrolux Gas Dryer: E66 error
Should the heater wire have electrical continuity to the housing
Mar 08, 2012 | Electrolux EIED55H Dryer
Electrolux frididaire serial XD40615481 02/04 electric heater comes on then goes out after a few seconds, fan stays on and drum keeps turning.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 31, 2010 | Electrolux EIGD55H Dryer
Ariston AS66VXNA dryer - everything works but no heat- looking for a schematic to check out and troubleshoot - where can I get detailed schematic?
You can find a manual for your model here>>>>>>>>> http://laundry.manualsonline.com/manuals/mfg/ariston/asl70c_1.html Let me ad that you may have just one side of the 240 volt circuit breaker or fuse set tripped or blown allowing all of the electronic functions, but not allowing the full 240 volts across the heating element. One way is to check the fuse box first and then proceed to measure voltage across the heating element after turning on the dryer. Please use caution while doing this. Ariston Clothes Dryer User Manual ManualsOnline com
Jan 17, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
White westinghouse
I have the same AEG T57800 dryer.  Problem, no heat. Couldn't find a service manual anywhere on the net. Checked for fuses and saw none. Thermostats on heater appeared fine, showing current flow. Replaced heating element 112 54 84 41/8, via local dealer - Respond Services from Electrolux UK in Durham DL5 6ED (£68), still no heat.  Called service tech who replaced the PCB - 973916012018008 (£135 + £85 callout charge). Very, Very annoyed at this as the dryer is only 3.5 yrs old.
Dec 11, 2007 | Dryers
Washing Machines Logo
138 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
