Question about Singer Sewing Machines
My sewing machine does not working..only the wheel is working.the parts og the needle and thread is not working
    Sergeant:
  • 194 Answers
May i know the model of your sewing machine
Posted on Mar 23, 2011
How to thread a bobber model SE 200JjoAnnSewEssential sewing Machine
The thread will now go downward on the left side of the take-up lever.
  1. Locate and thread any thread guides, leading down to the sewing machine needle.
  2. Thread the sewing machine needle. Hold the thread with your left hand and turn the hand wheel.
  3. Watch for any thread to flap around.
Step-by-Step Guide to Threading a Sewing Machine - The Spruce.
or go to this link. How to thread bobbin Essential sewing Machine Google Search
Oct 26, 2017 | Sewing Machines
I cant figure out the bobbin part getting thread to come up to the needle please help or how to do the whole bobbin thing
Depending on the brand of machine, you insert your bobbin into the bobbin holder, thread the top part of your machine, including the needle, then turn the wheel on the side of the machine by hand and it will catch the thread that is in the bobbin and it will pull it up through the bobbin hole. Once it is pulled up through the hole, near your needle, you will pull the thread towards the back of the machine and leave it. Then start sewing.
Jun 09, 2016 | Sewing Machines
Needle wont pick up bobbin thread
START WITH: SHARP NEEDLE (NEW), GOOD THREAD (NOT FUZZY-LONG STRANDS), ADJUST TENSION OF BOBBIN AND TOP.
1. Check the bobbin area and make sure the hook(pointed thing) and bobbin are all secure.
2. After you have adjusted the tension and reinstalled the bobbin: Extend three inches of thread from the bobbin.
3. After threading the top place the thread under the pressure foot and hold on to the thread. Turn the hand wheel towards you.
4. The needle has went under the throat plate (feed dogs plate) and begins to rise. You should feel the thread get caught and give a little resistance while you continue to turn the hand wheel.
5. The bobbin thread should come up with the needle thread.
6. If this hasn't taken place check to make sure the needle is inserted the right direction and totally pushed in. Retry again.
7. Look at your bobbin while turning the hand wheel. The needle thread should ride across the bobbin case and exit to the top of the machine again.
8. If these have not worked you will need to have your machine timed or the hook replaced.
ATTACHED IS A GUIDE FOR SETTING THE TENSION.
May 30, 2015 | White Sewing 2999 Mechanical Sewing...
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
When I try to sew my machine jams a little every few seconds and is not sewing on top. When I try to remove the fabric it is stuck and there is a mess of thread underneath. I have cleaned and oiled my...
Although you already re-theaded and cleaned your machine, re-check this:
- Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your bobbin case. Re-thread your machine, reinsert and rethread your bobbin.
If that doesn't work, try this:
- Change your bobbin.There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
- Raise your feed dogs if your machine has this feature.
Note:
when you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Sep 24, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
The thread breaks after sewing about 4 inches.
http://www.sewusa.com/Sewing_Machine_Manuals/Dressmaker_Manuals/Dressmaker_101_Instruction_Manual.htm
You do not say what model you have. Check this site out, if you need a manual.
What you need to do is to give it a good cleaning.
MAKE SURE YOU KEEP THE SCREWS WITH THE PARTS TAKEN OFF AND MAKE NOTE OF HOW YOU TAKE THING APART SO YOU CAN GET IT BACK TOGETHER
If this is the old metal machine, (I love them) remove the screws and plate on the top, (set this aside)
remove screw and part from the left side of machine, (set aside)
remove the needle (note how needle comes out, flat side in the back)
remove the needle plate
You are now able to see most of the inner workings of the machine
Using a can of air (do not put too close to machine parts) dust all the open parts. Can also use old fime paint brushes to get into dmall areas
now using ONLY sewing machine oil, TURN the hand wheel by hand, put a drop of oil on parts that go in and out of each other, rub over each other (on top, over the needle area and in the bobbin area, (IN bobbin area you can use a q-tip with oil to rub the area)
If turning the hand wheel by hand to oil moved freely, you can plug in machine and run machine to get the oil in all the parts (this will lubricate the parts you just oiled.
Put machine back together,
Use the air agsin to dust between the tension disks.
When winding the bobbin, make sure it winds even up and down.
thread machine and try
MAKE SURE YOUR BOBBIN THREAD AND TOP THREAD ARE PULLED TO THE BACK BEFORE SEWING AND HOLD THE THREADS FOR THE FIRST FEW SITCHES, IF NOT THE MACHINE WILL PULL THE THREADS AND YOU WILL GET BREAKAGE
GOOD LUCK
Sep 05, 2009 | Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Brother CS-80 will not always thread the needle when I depress the thread cannister.
I get this problem too. I found that it might be because I've moved the wheel while sewing previously and the needle doesn't go back to where it's supposed to be to be auto threaded correctly. To solve it, I just push the canister down until the threading parts are lowered. Once I see where the threader is positioned, I use the wheel to adjust the needle height to where the threader is, then I push the canister down all the way, and the needle is threaded. Hope it works for you!
Feb 22, 2009 | Brother CS-80
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Brother 3022 Mechanical Problem
Make sure your needle is in correctly. Check your threading again. If that does not work, remove throat plate, install new needle, turn hand wheel until needle is at its lowest position and observe if the hook is exactly behind the eye of the needle. If that is correct then you do not have threaded correctly. If it is not then the machine needs to be re-timed.
Oct 09, 2007 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
12 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
