E8 code on a Bompani washing machine - Washing Machines
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT this has to be worth a try!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
What does F3 men on a bompani BO-5021 dish washing and what is the solution
It is an error code and it should be listed in manual. If not go to mfg web site for guidance re code and then you can act accordingly. If it is for a bad part go to attached site for price, etc. Sometimes you can get the part number here and then enter it into ebay and get a better price for the same thing! Search Over 2 1 Million Appliance Parts
Sep 02, 2017 | Washing Machines
I have a Daewoo washing machine DWD-F1011 S, 7 KG..IT STOPS AND gave us an error with code E8.. HOW CAN WE SOLVE IT?
this is what I found E8 Washing machine motor error detectedA fault has been detected with the main drive motor.
  • Check motor connection block
  • Abnormal loading condition
Mar 13, 2015 | Daewoo Washing Machines
need more info
how old is the machine
Jan 09, 2014 | Washing Machines
I have problem show me E8 can you help
E8 Error Code
Temp too high on low temp washes
Normally this will be the wash temperature thermistor or NTC that's faulty.
Jun 20, 2011 | Washing Machines
Bompani washing machine i lost the manual can i download it from the net?
I have given up trying to find Bompani Washing Machine manuals on the net. Ian
Feb 07, 2011 | Washing Machines
User guide washing machine nikai
I have nikai top loading washing machine6.5 kg, machine showing error code E8 , what is the problem, i have no manual booklet , so please tell the problem to solve.
Jan 28, 2011 | Washing Machines
I need a user manual for bompani bo 02727 washer machine
Sir,
i have a bompani W/M BO 02727
can i hav manual- i dont know how to operate proper?
Jan 03, 2011 | Washing Machines
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Washing Machines Logo
177 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
