Question about Car Audio & Video
Im trying to figure out where the fuel rail on a 1993 bmw 325i is located?
  • 22,326 Answers
It runs along the top of the engine so look for the injectors and then you will see it unless this vehicle has monopoint injection system then it will not have a fuel rail
Posted on Mar 23, 2011
1992 325i bmw no fuel in fuel rail to start the car has a new fpr fuel filter fuel lines and fuel pump but no fuel is getting in the rail and rail is not cloged air flows through it freely
check for a vacuum in the fuel tank that is preventing the pump from moving fuel through the system. Air should not flow freely through the manifold as there is a regulator in the system that maintains the fuel pressure for the injectors. It should stay shut for a pressure of around 50 psi before it allows the air to flow out
Jan 21, 2014 | 1992 BMW 3 Series
How do I test fuel pump on 1993 bmw 325i. Car shut down while driving, will crank but not start.
go to fuel rail and will have bolt on the end (CRACK) this bolt open and (BUMP) key should have fuel spray if pressure is present let me know and please rate this
Mar 07, 2011 | 1993 BMW 3 Series
Where is the fuel pressure regulator located on 2.5l engine
FUEL PRESSURE REGULATOR IS ON FUEL RAIL WITH THE FUEL INJECTORS.THE FUEL PRESSURE REGULATOR ALSO HAS A VACUUM LINE GOING TO IT.THE FUEL INJECTORS AND FUEL PRESSURE REGULATOR IS UNDER THE INTAKE COVER.
May 21, 2010 | 1994 BMW 3 Series
How can I make fuel injectors fit for 94 325.i 2.5 L6 BMW
Buy the correct ones. did he/or you compare old and new before switching. One must be taller than the other
Jan 20, 2010 | 1994 BMW 3 Series
How do i put fuel pressure regulator in my 1994 BMW 325i
Fuel pressure regulator is located on the fuel rail. 1. Remove top engine covers and fuel rail mounting bolts. 2. Disconnect vacuum hose. 3. Remove regulator clamp, noting position of regulator. 4. Pull regulator out with shop towel (full of fuel) don't lose thrust washer behind. 5. Replace with new O-rings.
Jan 04, 2010 | 1994 BMW 3 Series
Bmw 325i engine number
The serial number is located on the lower left side of the block, toward the front.
Feb 17, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
