Question about Electrolux Lux 7000 Bagged Canister Vacuum
Return cord on electrolux canister vacuum with bag purchased in 1969
How do I install a new cord spring for the electric cord return.
  • woodycrest1 Aug 08, 2008
    how can I get a repair manual for an electrolux canister vacuum purchased in 1969?
  • woodycrest1 Aug 12, 2008
    How do I install a new coil spring for a canister electrolux ( circa 1969 model) cord return?
    Problem Solver:
  • 13 Answers
Your machine should still be under warranty which is voided if you do the work yourself or have another vacuum shop do it for u.
Posted on Oct 03, 2008
I have an Electrolux Guardian Canister vacuum. The power cord was damaged but the cord winder still works fine. I have ordered a replacement cord and need to know how to remove the old cord and install...
I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
May 24, 2011 | Electrolux Guardian Bagged Canister Vacuum
I have a electrolux 7000 my cord brok off and it got succked in. igot it apart. I DONY KNOW HOW TO PUT THE COIL SPRING ON THE POWER CORD WHEEL. NEED HELP
This is very difficult to reassemble correctly, and more difficult to explain properly. You need to take the vacuum to the nearest authorized Aerus Electrolux store for reassembly. Or call for free pick up and delivery.
http://www.aerushome.com/storelocator/
Mar 13, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
CORD SPOOL WILL NOT PULL BACK
Try tilting the vacuum to about a 45 degree angle. Gently tug and release the cord a few times. This usually will release the cord. If not, the cord winder may have broken, or the spring came loose, and it needs replaced/repaired. Take it to the nearest Aerus Electrolux store for help/repair.
Jan 19, 2011 | Electrolux UltraLux 2000 Bagged Canister...
I can't recoil the electrical cord. What do I need to do?
Open the bag door, remove the bag (leave door open)and then with a hammer and a blunt instrument(wooden dowel) Strike the side rubber "bumper" rails towards the open door side of the machine from the back of the vacuum. You should get it started and then it should easily pull out from both sides. you can remove the bottom of the vacuum and remove the cord "guard" to allow the cord to go thru also. The back is held on by the union of these two halves by dowel pins(plastic nubs) Sometimes the "spring" mechanism gets jammed from over pulling. Just simply roll the smaller wheel to retract the cord manually. You could try spraying the rollers with a silicone or graphite type spray to allow free movement of the spring. Hopes this helps. WFServices
Jun 25, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
My Electrolux Aerus auto rewind chord mechanism is broken. Is there an easy way to remove the back of the canister to replace or fix the spring there?
Take out the bag and keep the door open.
While the bag door is still open, turn the machine upside down so you are looking at the serial number.
Pull the cord out one foot.
Use a puddy knife and put it between the rubber side rails and the **** end of the machine.
Use a hammer or malett to hit the putty knife from the back of the rubber bumber toward the bag door.
Pull the rubber bumber stright out on both sides.
Once both bumpers are out pull the lower body of the canister from the **** end toward the intake of the machine.
Once the bottom is open you can then service the motor, cord winder, switch, and all other components.
For all the parts to fix the machine visit: http://evacuumstore.com/c-69-electrolux-accessories.aspx?manufacturerfilterid=0
Feb 28, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
Oct 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Auto rewind for the electrolux oxygen 3 ultra
HI
If this isnt working correctly, take it back. It wont get better
Feb 20, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Automatic cord return
if it is anything like an electrolux there is a coiled spring inside that free wheels around a hub. pulling the cord too far out makes the spring slip on the free spinning hub. you may need to take apart the vac and rewind the spring.
Aug 28, 2007 | Panasonic MC-V9644 Bagged Canister Vacuum
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
118 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
