Question about Canon CanoScan 3200F Flatbed Scanner
Hi , i cant scan jpegs anymore only pdf files since i installed windows 7 ive updated drivers ets im running 32bit , but it keeps coming up error code 12 1780 thanks
  • 158 Answers
Make sure the service for the canon scanner is running
start>search>services.msc look for canon service and check if its running, if its not put it in automatic then start it. hit apply then ok
Posted on Mar 23, 2011
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
EPSON L355
EPSON L355 EPSON Drivers and SW
Jan 27, 2014 | Epson Office Equipment & Supplies
Bluetooth can send but cant recieve
Maybe there is no Windows 7 driver for it. That's one of the pitfalls of Windows 7.
May 08, 2012 | Computers & Internet
I cant install nvidia geforce fx 5600 on windows 7ultimate 32bit O.S any solution?
get the vista 32bit drivers for it,ive come across the same problem a few times with 7 on outdated hardware and for me the vista drivers just worked as well
Mar 08, 2011 | Microsoft Windows Vista Ultimate Edition
Printer scans OK but will not save file as a PDF document I am running Windows 7
There are some possibilities not to save as PDF file from the Scanner.
1. Driver compatibility.
- You should install windows 7 compatible driver of your scanner by clicking this link. Select your operating system first (Windows 7 or Windows 7 64-bit), Then click on the link of the file which is listed under the Drivers headline. (mp760vst.....exe file). Download and Install (run) it in your computer to update your printer driver.
2. Software configuration.
- You need to setup the menu while saving. And you must know some properties related to the PDF saving.
For example: You cannot select [PDF] or [Multi Page PDF] when selecting an image scanned at 5105 pixels or more in a horizontal direction.
To read the detailed set up informations related to the software configuration and saving as PDF, please download the Software Guide of your printer by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 12, 2010 | Canon PIXMA MP760 All-In-One InkJet...
System error e225
Canon imageCLASS MF4150 And ERROR E225 maybe others
Canon imageCLASS MF4150 Firmware Update V062 Windows 2000/XP/Vista/Windows 7(all x32/x64) from Canon Multifunction .
Hi there
This is because you need to update your Firmware,
So what I have don for you I have found the Update you need and I have put it on my website for you to download, this is a update for Vista / Win 7 / All 32Bit and 64 Bit.
Click Link = http://www.4all2sell.com/driver/Canon-MF4150_FirmwareUpdateTool_V062.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website is only there foe a limited time.
Apr 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Can not scan a document in a PDF file on WIndows 7
Hi there
Feb 11, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Imfc 4122 laser printer print scan copy some error display E225
Ok try this I know not same number printer as yours but who knows may work.
ERROR E225 Canon imageCLASS MF4150 And maybe others
Hi there
Dec 27, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon CanoScan 3200F Flatbed Scanner Logo
121 people viewed this question
old marine
old marine
