Ac plug doesn't work on gateway - Computers & Internet
    Scholar:
  • 161 Answers
Power supply is probably bad.
Try another power supply to check it out.
State the problem more clearly and throroghly.
Posted on Aug 03, 2008
Do some Gateway laptops only work when using battery instead of using AC?
I would start by replacing my AC adapter. Is sounds like a short in your power supply. If that doesn't fix it then it is an issue with the laptop.
Jan 18, 2013 | Gateway Computers & Internet
Gateway laptop won't come on
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Nov 04, 2012 | Gateway MX6027 PC Notebook
Charger light goes out when plug in computer
it could be that the connection jack on the mainboard has been dislodged from the solder joint, common among Gateway comuters and HP units too. is the DC jack loose from the notebook ? if so thats the issue it seems. You will have to bring it to a computer person to resolder. if not and youc an do it yourslef, save money -- but be careful not to damage anything on the mainboard.
Jan 03, 2012 | Gateway NV5207u Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Gateway MA7 (MX6955) Will not boot up, or power on. Battery and AC plugged in battery LED light flashes 4 times and nothing... battery in AC unplugged.. same thing... battery out, AC plugged in.. nothing,...
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
Oct 08, 2009 | Computers & Internet
Gateway MX6428 Power Problem
faulty wiring in the wall (hopefully not) or the AC adapter try another adapter or outlet
Aug 12, 2009 | Gateway MX6428 Notebook
Gateway Notebook ML6721 going back and forth between battery & AC
the socket where the cord plugs into the back of the laptop gets wattered out and does not make a good connection when it gets this way. I suggest that not move it so much it kinda defeats the purpose of a laptop. though
Jun 22, 2009 | Gateway ML6721 Notebook
Gateway MT6840 Laptop will not power up
have you already tried to power up your laptop without the battery, only with the powersupply docked in?
If this works, you´ll have to replace the battery or use the laptop without a battery.
If this doesn´t work, just take the full battery from the other laptop try to power up the laptop without the power supply docked in.
If this works, your latop motherboard is broken and till it is replaced, you have only the chance to work with a battery and reload it with another latop.
Jun 02, 2009 | Gateway MT6840 Notebook
Gateway 7330gz Laptop Won't Charge
Could be your connection inside the laptop itself.
They tend to go easily in gateways.
The wear and tear from plugging it in and out.
Cost approximately $70.00 - $100.00 to repair.
Can usually get the best price at a small computer repair store
Jan 12, 2009 | Gateway 7330GZ Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
