Question about HP 12c Calculator
Do you have advice in calculator choice between HP 12 c and the TI BA II Plus Professional Financial Calculator? Assuming that I get proficient with RPN (which I'm learning now); is one faster than the other? more functions?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
The 12C is more expensive and more powerful than the BAII+Pro. The HP is also programmable, which the TI isn't. Starting from scratch (assuming you've never used a calculator before---a somewhat unreasonable assumption) the TI might be easier to learn, at least initially. But after a certain point, the HP will leave the TI behind. The HP is faster and more capable.
There are at least three different versions of the 12C available. There's the original 12C, the 12C Platinum, and the current 12C. The only way to tell the difference between the two non-Platinums is to look at the battery compartment---the original uses three button cells while the newer uses two coin cells. The newer one is MUCH faster. The Platinum, however, can use RPN or algebraic.
Unless your choice is limited to the 12C or the BAII (by the requirement of an exam, perhaps), you might want to look at the HP 20B and the HP 30B. Programmability aside, they're even more powerful and easier to use and faster than the 12C, and the 30B is also programmable.
There are other considerations, of course. Factors such as the feel of the keyboard, the 12C's landscape orientation as opposed to the others' portrait orientation, etc, are all matters of personal preference.
Disclaimer: I own multiple HP and multiple TI calculators. I tend to use HP calculators for calculating, while I use TI calculators to answer questions here at FixYa.
Posted on Mar 23, 2011
Testimonial: "Ha!!! In fact my choice is limited by the CFA exam."
Why are some numeric keys faded?
the electronics under that portion of the display must have been damaged somehow. find out if there is a way to replace the screen. if there isn't, you might need a new calculator
May 18, 2015 | Texas Instruments Ti Ba Ii Plus...
I need to use the EE button on my BA II plus professional finanacial caluclator. I need to calculate 2.06 * 10^23 divided by 3.78 * 10^28...Help?
If you do not have the Enter Exponent key (EE) you can use the general power key marked [Y^x], the one above the [9] key. Use parentheses to enclose the (10^23) and (10^28).
Frankly, if you have to do many calculations of this kind, better buy yourself a scientific calculator.
Jun 30, 2014 | Texas Instruments BA II PLUS Financial...
I have two BA real estate calculator with the same problem. Each one is slightly off in the calculation. Example. $100,000 loan 6% rate 30 year term should have a 599.99 payment and when I input this...
$596.57 is what I get with payments occurring at the beginning of the month. Set it to handle payments at the end of the month. My calculator gives $599.55 for this case.
I'm not sure about the BA RE, but on the BA-II Plus you change the Begin/End setting by pressing 2nd [BGN] and 2nd [SET].
Mar 09, 2011 | Texas Instruments BA Real Estate...
I have an old TI BA-II (not Plus) I need to reset it to the "FIN" mode
This procedure is valid for The TI BA II (executive Business Analyst). Press [2nd][FIX] to access the (MODE) setting. As you execute the key sequence [2nd][FIX] the Mode change cycle s between FIN STAT and the regular computational mode.
Jan 13, 2011 | Texas Instruments BA II PLUS Financial...
TI BA 2 Plus Calculator: Cannot figure out how to use log(10) function, not the natural log but the base of 10 log
The BA II+ does not have a key for the common logarithm function. You can calculate the common log of a number by calculating its natural log and then dividing by the natural log of 10.
log10(x) = ln(x)/ln(10)
The same procedure works for logarithms to any base.
Dec 14, 2010 | Texas Instruments BA II PLUS Financial...
Digit missing in display
It is probably the flat wire. Try taking it apart and resetting the wire connections.
Jun 23, 2009 | Texas Instruments BA II PLUS Financial...
No decimal display on TI BA-II calculator
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Jun 03, 2009 | Texas Instruments BA-II Plus Calculator
Help the the ba 2 plus
You might have to contact Texas Instruments for a paper copy, but for now, I found this for ya. It is a rather large "pdf" though.
http://education.ti.com/downloads/guidebooks/financial/baiiplus/BAIIPLUSGuidebook_EN.pdf
Sep 05, 2008 | Texas Instruments BA-II Plus Calculator
HP 12c Calculator Logo
217 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
