Question about RCA RP5430 Clock Radio
I cannot get the FM radio to tune properly it keeps flipping to random stations
2 Suggested Answers
FLASH O Ride
SOURCE: Help
Possible solution for some of the problems listed: Turn the clock upside down so that the label is readable in the upper left area. On the right side you will find a compartment which may have two "AA" batteries installed. These back up the setting when the clock is unplugged.
To reset the clock, you will have to BOTH remove the batteries AND unplug the AC power cord. Also, make sure the batteries are not dead.
Finally, although I cannot confirm this, there is an opening directly under the label (still looking at the bottom of the clock) which appears to be a "Reset" switch. A pointed object such as a ballpoint pen or toothpick will be needed to press this recessed button. Hope this helps. Mine is working just fine.
Posted on Mar 15, 2009
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
How Ido tune it l have no manual.Can you please help.many thanks
Radio With Manual Tuning - Alibaba
www.alibaba.com > Automobiles & Motorcycles > radio > radio with
Radio With Manual Tuning, Buy Various High Quality Radio With Manual TuningProducts from Global Radio With Manual Tuning Suppliers and Radio With ...
Help Guide ' Tuning in an FM radio station manually ... - Sony
https://www.sony.co.uk/.../emanual/.../TP0000016777....
Sony CorporationThe headphone cord of headphones is an FM antenna, therefore, connect headphones to the (headphone) jack when listening to the FM radio.
Tuner (radio) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Tuner_(radio)
WikipediaA tuner is a subsystem that receives radio frequency (RF) transmissions like radio ...Older models would realize manual tuning by means of mechanically ...
[PDF]Tuning into a Radio Station - Onkyo
Dec 16, 2015 | Audio Players & Recorders
I experience a problem with the unit in radio mode. When switched on the radio do not latch on the station (only background hiss) Only after repeatedly toggling the BAND button (random times)it will l
Try turning off the AutoTune (lock, center....) function (on most FM tuners) and retune manually to the errant station. Then reactivare auto-tune, or not. Toggling bands (as you put it) means that sometimes signal will center, sometimes not...a more or less random thing as you say. That suggests resetting station auto lock. Bear in mind though that certains stations can simply be uncooperative depending on numersou factors such as transmit location, reception terrain, and so on.
Oct 03, 2014 | Crosley CR7002A Turntable
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
I can not get the sound to go through the radio
Turn on FM modulator in OH monitor from the menu screen. Set station on screen, tune stereo to station.
Sep 24, 2010 | Directed DEI AutoMate OHD1021 Overhead LCD...
XM radio tunes to random station when turned on
There is an internal battery to hold the station and presets. It is probably no good. Either that or there is something very wrong with the unit.
Here is what I recommend. Call XM. Tell them your receiver is not longer functioning correctly and that you are thinking about canceling your service because you don't have a receiver. They will then offer you a receiver because they don't make much money on them, the make their money on the service.
that's how you get a new free satilite radio.
Dec 24, 2009 | XM Radio (XMP6000)
How to manual tune the radio to a station and not use the scan
i have the exact same problem. i bought a fm transmitter, so i need to tune to a unused fm station in my region wich i cant do because the audi concert tunes up automatic and skips the unused stations ... HELP !
Nov 23, 2008 | 1997 Audi A4
Help
Apr 06, 2008 | RCA RP5430 Clock Radio
Setting the stations on memory
OK HERE'S WHAT YOU DO
1. USING THE UP AND DOWN TUNING, TUNE IN THE STATION
2. PRESS THE MEM SWITCH (LEFT SIDE OF ROUND SWITCH)
3. PRESS STATION LOCATION
4. PRESS MEM AGAIN ---- THAT'S IT
SUMMARY: TUNE, MEM, SET STATION, MEM
Jan 01, 2008 | GPX RDT4004SP AM/FM Radio
RCA RP5430 Clock Radio Logo
116 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
