Question about BenQ T221W 22 inch LCD Monitor
Power light is blinking, but no diplay - BenQ T221W 22 inch LCD Monitor
    Scholar:
  • 60 Answers
Hi.
If the Power Light blinks, its means that the monitor is in ' STAND BY Mode '.
Monitor stays in Stand-by mode only if it does not getting any signals from computer.
please check the cable which connects the monitor and computer are connected properly.
Also check that the cable is connected to the proper slot of the computer.
If you hear some continuous beeps when you start the computer, then the problem may with the display card ( Video Adapter or Graphics card ) on the PC.
thank you
Posted on Mar 23, 2011
My lap top del d 620 does not power on even directcty connected through Ac Adopter. two light at the left corner blink for about 30 seconds and then terned of. no dcreen diplay. no working,
Hi, about the blinking lights on the machine you have on your machine, it means that there is a problem on the hardware of your computer it could be memory, video card or even motherboard problem, it means that you need to have it service to fix the problem. I suggest try to get in touch with the manufacturer if happen the machine is in warranty to have your machine service. Hope it helps.
Aug 08, 2011 | Dell Latitude D620 Notebook
Vostro 1510 no diplay on screen. All indications lights are blinking
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Computers & Internet
Monitor black but power light blink green
The 470uF 25 Volts capacitors on the power supply board are probably bad. Replace them all and tell us the result !
Feb 24, 2010 | Hannstar I-Inc TW-191D Monitor
Kodak DC 260 The camera does not turn on. For some seconds the power light blinks green, then it changes to blinking red and the diplay shows ''E 11''. Then it turns off.
It could be something more serious, or as simple as inserting fresh/fully charged batteries, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Sep 01, 2009 | Kodak DC265 Zoom Digital Camera
Can't get the ansewering machine to work? we were gone for 3 days. When we got home the ansewering machine was not blinking, I thouht no loved me! No messages. then relatives called saying they had tried...
You might try unplugging the AC power to the unit, let it sit for 5 minutes, and reconnect the power. That sometimes resets the unit to the factory default. You can then reprogram.
Aug 23, 2009 | Panasonic KX-TG1033S Cordless Phone
Canon Copier Key Panel Problem
Replace display touch control panel
Deshpande +919420906982
Oct 19, 2008 | Canon imageRUNNER 400S Copier
BIS 34-D phone - Display window blinks date time beeps multiple times/day
The display will blink if power is cut either by unplugging or if the control system is power-cycled. The cause of the power glitches needs to be located & corrected. Changing the ring tone/cadence depends on which control unit is being used.
May 27, 2008 | AT&T Merlin BIS 10 Phone
BenQ T221W  22 inch LCD Monitor Logo
280 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
