Question about Dishwashers
Homemaker Hm0607 dishwasher stuck on drain mode
2 Suggested Answers
BElectric
  • 1140 Answers
SOURCE: Hi I have homemaker dishwasher
Hello Colin,
Yale Prima are not specifically a parts company, but they are probably best placed to help you. They do have a spare parts manager to deal with customer service enquiries. I suggest contacting them unless you have not already done so:
http://www.yaleprima.com.au/support.html
Phone: 1300 366 155
If they are unable to help you, I should be able to find a replacement for you but you're going to have to help me to help you. Your dishwasher is an unbranded Chinese manufactured unit which has been given the Kmart house-brand 'Homemaker' badge and an arbitrary model number. This makes finding parts rather difficult.
That's the bad news. The good news is your dishwasher uses some common third-party components from major manufacturers which will also be used in some major brand appliances. The trick to finding the part is to identify a major brand dishwasher which uses the same controller and then search using the dishwasher manufacturer's part number, rather than the OEM (Invensys) part number. Hoover and Candy generally use Invensys controllers, so there's a good chance your controller was also fitted in some of their dishwashers.
That's where the good news ends. SM10 is only the motor number, 31E06 returns no results and 'Invensys 16' isn't the part number (too short) and it isn't a specific enough term to search for.
If you can find any other numbers on the timer/controller (not the motor) and/or upload one or two images of the controller somewhere on the internet and post the links here, I should be able to track it down for you.
Is this the one?
Or maybe it's more like this one?
http://www.buyspares.co.uk/candy/cd474-uk-32129017/timer/product.pl?pid=288685
Any additional information and/or images you can supply will be of great assistance!
Thanks,
BElectric
Posted on Apr 08, 2011
Wont turn off/stuck in drain mode
This sounds like a washer and not a dishwasher. The rubber you are referring to is the door gasket and it needs to be replaced in your case. It has got into the pump and it's plugging it. Please remove any debris from the pump and start the unit again.
Mar 11, 2014 | Dishwashers
I have a BOSCH SH33M02UC that is stuck in a constant draining mode and won't work. I just paid someone $99 to tell me that the float was stuck because a mouse flipped the switch. It happened again and I...
https://youtu.be/SIFas6dI2OE This is a video for a Bosch not draining that kind of shows you the dishwashers mechanics. Might help. Or give you an idea of how to do figure it out yourself. There are also many videos about dishwashers not draining that might help. Let me know how it works out :)
Mar 02, 2018 | Bosch Evolution 300 SHE33M02UC Built-in...
What men cod e4 on dishwosher kenwood kdw12st3a
Hi
Error e4 on Kenmore usually occurs when there is drain clogging or due to debris stuck in the bottom of the dishwasher. Drain out the excess water from the dishwasher, now remove the mesh and the filter. Now, check and remove any food material or debris stuck. Now pour 1-2 litres of luke warm water and let this water drain. After this replace the parts and run the dishwasher on eco mode without any tablets or soap. Try this 2-3 times and then reset the dishwasher by unplugging it for 5-10 minutes.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Kenmore 15762 Dishwasher
Air condition homemaker model hmasw-h12a4/ea-2 code error 3
homemaker H12A4/EA-2,dripping moisture from internal unit.I have cleaned drain pipe from unit,but don`t know where to go inside unit to find drain hole where it must be clogged. Do you have a diagram?
Jan 13, 2010 | Heating & Cooling
Our Asko 1885 Dishwasher is stuck in drying mode
Check if the other functions of the dishwasher are OK such us when filling, draining or the heating element heats up properly. The control board may have detected some errors and it is not proceeding. You may have to have the parts involved in the faulty function checked out such as the valves for the drain and the fill if your machine is not filling or draining properly or filters blocked. Check the heating element and inspect the assembly for burns especially on the relays. The machine may not be heating correctly that is why it is not finishing the cycle. If these parts checks out OK, you may want to have the control board checked out or replaced.
Oct 09, 2009 | Asko 24 in. 1885 Built-in Dishwasher
My SHY56A05UC Basch dishwasher runs and dose not shut off
The dishwasher is stuck in drain mode because there is water in a catch leak area underneath, it may have been caused by soap suds over flow or disposal backup. Remove bottom kick plate and vacuum out any water, then run dishwasher again and look for water leaks.
May 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Growing dishwasher
ok i will tellyou the secret. your unit is in drain mode .there is water in the base of your dishwasher and it has to dryed out to come out off drain mode. when you dryit then hit cancel and the unit will work. to get the water out you have to take off panel side to see the base. trade secret :0)
Apr 13, 2009 | Bosch 24 in. SHX36L05UC Stainless Steel...
Dishwater won't stop trying to drain even when door is opened
The drain valve is stuck open. This is electrically operated, but may have some debris inhibiting movement. If you can physically move it (with the power off) this should repair the problem.
Apr 21, 2008 | Bosch SHU9925UC Built-in Dishwasher
Dishwashers Logo
150 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
