Question about Pioneer VSX-53TX Receiver
My Pioneer Elite VSX-53TX volume quit in the middle of a video. the read out on the unit says - - muting - - and no, we did not push the mute button. do you have any idea how to get the volume back
  • Pioneer Master
  • 6,694 Answers
First of all remove all the speaker connections from the amplifier. After that power the amplifier and check the protect show or not . if not, then any of the speaker is damaged. If then also it shows protect you have to check the amplifiers hardware.
AV receivers shows protect mode , when there is a hardware fault in side it. Its a warning that some thing is wrong.
Normally AV receivers show this when any of the output amplifier get some problem. there are six amplifiers in this AV receiver. May occur when the output diver transistors of any of the amplifier become shorted. if the output transistor get shorted this will lead to flow of current through the speakers. To prevent this there is a protection circuit for each channels. One combined output of this protection circuit is connected to the system control. when the any of the output amplifier fails, the protection circuit detects it and switch of the speaker and sent data to the system control. when the system control get this data it will give a warning to the customer through display that PROTECT.
You have to check the amplifier.
for that you need digital multimeter,soledring iron screwdrivers etc
open the amplifier , then power it on. connect the negative terminal of the multimeter any where in the chase( metal body of the amplifer). then connect the positive terminal to all the output transistors emitter pin one by one . the voltage should be bellow 0.5V. If any of the emitter of the transistor shows voltage more than 0.5V., then that amplifier stage is faulty. Remove the transistors and check it. if it is shot then replace with a new one.
after replacing the transistors do not power up the amplifier directly from the main. You have to put a bulb of 60 watts in serial.
You can do this easily remove the mains fuse. put the bulb in a holder. now you have to wire from the holder. connect one of it to the one end of the fuse holder and the other wire to the other end of the fuse holder. Why using a bulb is, if there is any further problem in the amplifier stage on which the transistors replaced, there is a possibility of the new transistor get damage. if we use a bulb in serial with its mains supply ,when any overload in the amplifier occur the bulb will drop the current, by lighting itself.
After connecting the bulb in serious power on the amplifier. watch the bulb. It should light for one or two second and go dim . if so check the display, is there is protect mode is on or not . if not and come back to normal operation ,then remove the power , remove the bulb insert fuse and check
connect the power and check.
If the bulb shows bright light then there is some component also faulty in the same amplifier. after removing the power you have to check again the amplifier stage of which the transistor is replaced, for any other faulty components.
ok
Posted on Mar 23, 2011
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
No sound
On the bottom row of buttons next to the headphone jack, the button on the far right is labelled speakers. Try pressing that button to turn the speaker outputs back on.
Nov 24, 2011 | Pioneer Elite VSX-91TXH
My Pioneer VSX-53TX is not turning on.
Replace standby transformer in receiver to solve the problem.
Required transformer is available in PartStore.com
Thanks.
Aug 05, 2011 | Pioneer VSX-53TX Receiver
My vsx-305 is stuck on muting and i don't have a remote?
Rotate the volume knob. Contrary to popular belief, manual switches on the front of a unit DO have functions.
May 24, 2011 | Pioneer VSX-305 Receiver
Why does my pioneer vsx-d557 automatically go into MUTING WHEN I turn it on?
Maybe you have MUTING selected. Turn the volume knob up or toggle the Mute control on the remote.
If it defaults to muting on power up find the manual and search it for a default volume setting.
May 15, 2011 | Pioneer VSX-D557
No sound output from my pioneer vsx-1014k using either CD, tuner or home theater inputs.
IOW, no audio from anywhere.
If it otherwise looks alive...
WARNING: Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jan 19, 2011 | Pioneer VSX-1014 Receiver
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
Feb 11, 2010 | Pioneer VSX-27TX Receiver
My pioneer vsx-d507s keeps turning on mute randomly and I can't turn it off of mute There is no mute button. I would really like the owners manual
I have had the same problem, since there is no "mute" button on the receiver panel. My power cord on the receiver was plugged into my cable box and I was told this is not correct. I unplugged the receiver from the cable box and plugged it into my power surge protector and no more "mute"!!! Hope this helps.
Jan 01, 2010 | Pioneer VSX-D509S Receiver
I have a Pioneer Elite VSX-05. When I turn it on
check in front of your receiver and check the button wheres say mute press that button and
see if work or buy universal remote.
Aug 17, 2009 | Audio Players & Recorders
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Oct 04, 2007 | Pioneer VSX-D307 Receiver
Pioneer VSX-53TX Receiver Logo
201 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
