Question about Epson Office Equipment & Supplies
There is no indicator of levels in ink cartridges. What do I do?
  • 41 Answers
Most printers have a configuration and status selection you can use on the operators pad of the
printer. The printer will print out a page with its ink levels.
Posted on Mar 23, 2011
I have a photosmart C4700 and it won't print in black How can I tell if it's out of ink?
Follow these steps to check the ink levels: >Click Start . >Click Printers and Faxes . >Right-click the icon for your printer , and then click Printing Preferences . >Click the Features tab. >Click the Printer Services button. The Toolbox window opens. >Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge.
NOTE:Depending on the printer, the estimated ink level indicators can vary in appearance.
>If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
Aug 13, 2011 | HP Office Equipment & Supplies
Where can I find a diagram of the black ink cartridge so I can locate the proper place to re-ink it?
NOTE: If a refilled or re manufactured print cartridge, or a cartridge that has been used in another product, is installed the ink level indicator is inaccurate or unavailable.
  • Make sure that the product is turned on and connected to the computer.
  • Click Start and click Control Panel .
  • Double-click the Printer and Faxes folder.
  • Right-click the icon for the product and click Preferences .
  • Click the Services tab, and then click Service this Device .
  • The printer Toolbox opens. Click the Estimated Ink Level tab. A graphic showing the estimated ink levels appears. The graphic shows both the color and black ink cartridge with the ink level indicated by the fill inside the cartridge diagram. Figure 1: Estimated ink levels - both cartridges lowc738e3b.gif
    Sep 12, 2010 | HP DeskJet 6540 InkJet Printer
    How to reset the ink level of my hp officejet 6500
    Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
    • The exclamation mark (! ) symbol indicates a low ink level.
    • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
    Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
    1. Make sure the product is on and connected to the computer.
    2. Open HP Solution Center .
      • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
      • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
      • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
    3. Click Settings .
    4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
    5. Check the ink levels displayed on the Estimated Ink Levels tab.
    Figure 2: Estimated ink levelsc00670267.gif
    Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
    With new cartridge indicates low ink level,
    The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
    otherwise you will have to replace the cartridge .
    Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    F4280 printer and hp 60 cartridge
    keep the cartidge in Hot Water for 30 minutes. maybe it works.
    May 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
    Ink level didn't change
    s.gif Deskjet 5100 series
    1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
    2. Click Utilities .
    3. Click View ink levels .
      • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
      • If the cartridges contain a sufficient amount of ink, continue to the next step.
    4. Click Printer Maintenance .
    5. Click Clean Cartridges .
    6. Follow the on-screen instructions.
    ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
    May 29, 2009 | HP Photosmart D5160 InkJet Printer
    Polling the ink cartridges for available ink level.
    http://files.support.epson.com/pdf/r220__/r220__pg.pdf
    then click on replacing ink supply, and the first box down tells you about ink cartridge levels.
    There you go Utah
    Please leave rating...thank you kindly
    May 10, 2009 | Epson Stylus Photo R220 InkJet Printer
    How do you check ink levels
    Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
    1. Open the Printer Toolbox . There are two ways to do this:
      • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
      • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
    2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
    Nov 23, 2008 | Office Equipment & Supplies
    13 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
