Question about Toshiba 57H81 57" Rear Projection Television
When I turn on my toshiba tp4880a tv it turns off immediately and then I have to unplug and plug it back in several times to get it to power on
  • 84 Answers
You are probably experiencing primary stages of a convergence IC failure. This repair is composed of replacing two output IC's and alignment. Standard repair is around $350
Bill W
integrityhomeworx.com
Posted on Mar 23, 2011
Testimonial: "thank you"
My toshiba tv won't turn on
1. Verify the circuit it's plugged into is powered.
2. Change the batteries in your remote control. It requires (2) AAA's.
3. Unplug the TV for several minutes, then try again.
Apr 15, 2014 | Toshiba 32C100U 32 in. TV
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
Unplugged my 32LV67U to vacuum behind it and now it will not power up. Yellow LED keeps blinking and I waited several minutes but tv will not power up. Worked perfectly until I unplugged it. Called...
That wall outlet may have frequent surges so try another wall outlet see if it turns back on. If it turns on be sure to use a surge suppressor and never plug the TV directly into the wall outlet. The AC surges will kill the power supply of the TV in short time. See if there's a kill-switch near the ac adapter of the TV if there is turn it on.Get a surge protector/suppressor then try plugging it back in the wall. If still no power then the power board is already damaged, you can send the board too me and I'll repair it for you or seek your local repair center.
http://tvtechwork.webs.com/
Oct 18, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
Can not turn TV on
Failing power supply. It's 14 years old.
Feb 19, 2018 | Toshiba MD14F51 14 in. TV/DVD Combo
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Toshiba 57H81 57" Rear Projection Television Logo
518 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
