Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
How do i unlock drawer - Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
    Habit-Forming:
  • 17 Answers
Hold the lock button in. There is a 2 stage lock. first beep locks the key pad. if you keep holding the lock button down it will lock the draw. Hold the button in for the second beep.
Posted on Mar 23, 2011
Bottom oven drawer stuck partially open. Cannot close or fully open. Model #316471000
Hello Dan, thank you for your post!
I understand that the bottom drawer of your Electrolux range will not close and it partially open. It is possible that your rail or drawer may be damaged or blocked. I would recommend pulling the drawer out to inspect it. If you pull the drawer out there should be tabs on the side to unlock in order to remove the drawer fully. The model number you have provided is invalid you can locate the model number on the serial tag. The serial tag can be found on the frame of the drawer. I look forward to assisting you. -Matt
Dec 25, 2015 | Electrolux 30" Self-Cleaning Freestanding...
Fisher Paykel D603 f1 code top drawer only, bottom one has no power and locked
Check out www.ApplianceRepairLesson.com. I hope this is what you needed, and it works for you. Good luck!
Nov 07, 2014 | Dishwashers
The soap drawer won't open. Never had this issue before.
Is the machine a front loader? Is the drawer on the front of the machine? What is the Brand? I have a Samsung front loader and my detergent/bleach & softner drawer pulls out from the front. There are two drawer release locks on the drawer track (one on each side) if the drawer will give you any wiggle try pulling or pushing up gently. This may unlock the track. It sounds like the drawer was pushed in too hard... hope this helps
Oct 13, 2014 | Asko W660
How can I pry open an unlocked but Jammed file cabinet drawer?
The issue is probably a worn out drawer interlock - that is to prevent you from opening more than one drawer at a time so the unit will not tip over on you.
Remove one drawer and check the mechanism (worn out or bent).
JOAT
May 09, 2014 | Office Equipment & Supplies
Wascomat 16n4 front of drawer broke off. how can
I have a Wascomat W655CO,
This morning I got a screen message, Wait doors is locked?
I waited but the door never unlocked?
Oct 26, 2013 | Wascomat Parts Washing Machines
Minolta di520 error code C0990
C990-C994 3rd drawer lift up and 3rd drawer elevator motor failure.Check the actuators and two motors .
Removal of the 3rd drawer:
1.Press the paper descent key and slide the 3rd drawe out to the front.If pressing the paper descent key does not allow you to slide out the 3rd drawer,insert a screwdriver or similar object trough the hole in the rear cover and unlock the drawer.
2.Remove 4 screws on the slide rails and pull the 3rd drawer out to the front.
3.Unplug 1 connector,loosen 2 thumbscrews to remove the connector board assy and remove the 3rd drawer.
4.Remove 4 screws,unplug one connector and remove the cover.
5.Remove two screws and the drive bottom cover.
6.Check the gears.
Aug 13, 2012 | Office Equipment & Supplies
The place where my fabric softener seems to be stopped up. When my clothes are finished washing, this spot is filled with water. How can I get the drawer out to check out this problem? I think the drain is...
Pull the drawer all the way out till it stops. At the rear of the drawer, you will find a button to push down and it will unlock the drawer to remove out completely. Good luck.
Jun 20, 2011 | LG WM1814CW Front Load Washer
ASKO 6021 washing machine, drawer locked
Reach under the drawer, right side and move the lock mechanism to he left. The drawer will unlock.
Mar 22, 2009 | Asko W6021 Front Load Washer
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Door won't unlock
pull out the dispenser drawer push down on the tab remove the drawer and there is a cord you can pull to unlock the door pull on the door same time you pull the cord
Feb 18, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
163 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
